Water Coolers: |
new products:
PowerCool 300
Although, specifically designed to cool all Everlast PowerTig and PowerPro series units with water cooled torches, these units can be easily adapted to many name brand torches for an economically priced alternative water cooler. Stainless and copper construction ensure that the unit will last for years to come. Each unit comes with matched plug to mate directly PowerTig 225LX and 250 EX units 220V output socket. |
PowerCool Series |
Rated Amperage |
Pump |
Maximum Input amps @ rated input voltage |
Capacity |
Maximum Operating Pressure |
PowerTIG 250 EX |
PowerTig 225 LX |
PowerTIG 315 DX |
PowerPro 226 |
PowerPro 226 |
PowerPro 256 |
| PowerCool W300 |
300 + 10% |
Stainless |
1.1@220 V 1phase 50/60 Hz |
2 gallons |
57 |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
| PowerCool W600 |
600 + 10% |
Stainless |
No |
No |
Yes |
No |
No |
No |
| * Call for special applications, special build to order. |
The EVERLAST PowerTig and PowerPro units are affordable - and effective - water-cooled torches. The PowerTig and PowerPro units easily adapt to a variety of circumstances, backed by excellent design and intelligent pricing.
Also, the Everlast PowerCool W300 works exclusively with every EVERLAST PowerTig and PowerPro 220v unit. The W300 water cooler works in 160 amp and higher operations, for TIG and for some MIG applications, too. The unit's features and benefits include:[read more...]
> It efficiently cools the TIG efficienty.
> The mechanism prevents overheating
> The mechanism is compact
> It has large fans
> Rated amperage is around 300 + 10%
> Stainless steel pumps are standard
> The mechanism has a copper construction
> It works with 220V for efficient operation
> It goes well with other brand of water-cooled torches
> Its maximum input amps are approximately1.1@220 V 1phase 50/60 Hz
> It has a 2-gallon capacity
> The maximum operating pressure of the device is around 57
PowerCool W600 water coolers:
Features & Benefits of PowerCool W600:
> It cools the TIG torch
> The device prevents
> The design is compact
> It includes large fans
> Rated amperage is around 600 + 10%
> Stainless Steel pumps are standard
> The mechanism has a pure copper construction
> It works with 220V for efficient operation [Collapse...]
Diesel Generators | Multi-Purpose Units | Plasma Cutters | Welders | TIG Water Coolers | Welding Helmets | Consumables | Spare Parts | Accessories Welders Word Press | Welders News | Sitemap | Welder Blog | Welding Equipment Blogspot | Welding Supply Articles | Welding Calculators
