SuperCut 50P:
Process: PAC
SuperCut 50P
SuperCut 50P
Features & Benefits
- Front air pressure adjustment makes adjusting pressure easy and painless. ( PowerPlasma only)
Make an offer for SuperCut 50P
Price : $649.99
Recommended Areas Of Use
- Cutting in all conditions where Oxy Fuel cutting is impractical, slow, unsafe, expensive, or otherwise restricted or undesirable.
Standard Equipment
- Torch
- Consumable starter kit
- Water trap/filter
- Air pressure gauge
Optional Equipment
- Welding helmet
- Consumable Kit
- Welding cart
Recommended Metals
SuperCut 50P
SuperCut 50P
SuperCut 50P
SuperCut 50P
SuperCut 50P
SuperCut 50P
SuperCut 50P
SuperCut 50P
SuperCut 40
SuperCut 50
SuperCut 50P
SuperCut 40 SuperCut 50 SuperCut 50P
Input Voltage 110/220V 1ph 110/220V 1ph 110/220V 1ph
Max Start Input Amps - - -
Max Running Amps - - -
Pilot Arc NO NO YES
Input Current 30A 35A 35A
4T/2T Remote Yes Yes Yes
OCV Voltage 200 V 200 V 200 V
Post Flow Timer Manual/Automatic Manual/Automatic Manual/Automatic
Duty Cycle @ Rated Amps 60%@ 40 A 60%@ 50 A 60%@ 50 A
Maximum Severance Cut Steel(Less 20% AL/SS) 5/8" 3/4" 3/4"
Recommended maximum cut @ 10-12 ipm in steel. Decrease by 25-30% for Aluminum 3/8" 5/8" 5/8"
PSI/CFM Requirements 55-70 psi/ 3.5 cfm 55-70 psi/ 3.5 cfm 55-70 psi/ 3.5 cfm
Shipping Weight 28 lbs 28 lbs 28 lbs
The EVERLAST Super Cut 50p is excellent cutter, which is versatile, expertly manufactured and efficient. The unit has a durable cycle of 60% of rated amperage capacity. The Super Cut 50p has an Adjustable Post Flow where the control will range up to 60 seconds to get better consumable and torch life.[read more...]
