SM100-N:
PowerSpool Series: For Power I-MIG welders and other brands with euro connectors
Process: GMAW (MIG)
SM100-N
SM100-N
Features & Benefits
Standard ergonomic design for operator comfort
Long service life with parts interchangeability with name brands
Easy change out of the wire spool
Strong drive mechanisms
Euro style quick connectors allow gun change out in seconds
4" spool capacity allow economical repair of aluminum with out expensive push/pull guns or large rolls of wire
Adjustable tension of drive rolls (some models)
Adaptable to any make MIG welder with Euro connectors ( May require changeover of power connector plug)
Make an offer for SM100-N
Price : $179.99
Recommended Areas Of Use
Artistic and structural designs
Marine repair of vessels
Fabrication of irrigation pipe and joints
Large container manufacturing
Food processing equipment
Recommended Metals
Steel
Stainless Steel
Aluminum
SM100-N
SM 3035-N
SM 200-N
SM100-N SM 3035-N SM 200-N
Rated Maximum Amperage @ Duty Cycle 135 A @ 35% 180 A @ 60% 200 A @ 35%
Connection Type Euro-Style Quick Connection Euro-Style Quick Connection Euro-Style Quick Connection
Wire Sizes 0.023-.0.035" 0.30-.0.035" 0.023-.0.040"
Maximum Roll Diameter 4" 4" 4"
Typical Use Hobbyist, General Repair Hobbyist, Fabrication, General Repair, Light Industrial Hobbyist, Fabrication, General Repair, Light Industrial
Cable Length 10 ft 20 ft 20 ft
Recommended Power I-MIG Match Power I-MIG 160 Power I-MIG 200,205 Power I-MIG 160,200,205
Guns And Torches, SM100-N:
Welding a complex skill, which requires patience, expertise and various forms of equipment. Also, welding torches use many energy sources such as: as flame, ultrasound, electric arc, friction, a laser, and an electron beam, among other forms of power.
EVERLAST has numerous accessories for MIG welding, including: MIG Consumables, Spool Guns, Trafimet MIG Torches and Binzel, and MIG guns. For TIC welding EVERLAST also carries plenty of necessary equipment. Some of these tools and accessories are:
Welding Gun:
Welding guns, which have a control switch, hose and gas nozzle. The tip consists of copper, and may be chemically treated to reduce any spatter. Consistent flow of shielding gas will ensure a proper weld area. This shielding gas passes through the gas for maximum results.[read more...]
