PowerUltra 164:
PowerUltra and PowerPro series: IGBT based Inverter Tig welder/Plasma Cutter
Processes: GTAW (PowerUltra) GTAW-P (PowerPro), SMAW, PAC
PowerUltra 164,185,205; PowerPro 164,205,226,256
PowerUltra 164
PowerUltra 164
Features & Benefits
- All-in-one portability
- Compact, yet powerful TIG welding/Plasma cutting features
- Easy to use controls with simple selector switch for process changeover
- Quick change out of torches for easy change from TIG to plasma back to TIG
- Low power consumption due to inverter design
- High duty cycle of 60% at rated amperages for TIG/Stick/Plasma
- Front air pressure gauge for easy verification of air pressure
- Over Current indicator warns when duty cycle has been exceeded
- Clean and smooth plasma cuts on virtually any metal
- Weld almost any metal (PowerUltra is DC output only, not suitable for Aluminum)
- Exceptional arc stability for TIG/Stick functions
Make an offer for PowerUltra 164
Price : $799.99
Recommended Areas Of Use
  • For use in areas where multiple processes are required for on-the-spot repairs or fabrication in shops or home garages.
  • Typically many motorsports enthusiast like to carry these units to the track for convenient and quick high quality repairs.
  • It is also an excellent choice for the person or business with space limitations or the portable repair business as both plasma cutter and welder are contained in one unit, reducing need to carry or store two or more units.
Standard Equipment
- Torch (Water cooled torch for PowerPro 226/256)
- Foot Pedal
- Consumable Starter Kit
- Argon Regulator
- Air Pressure Regulator
- Air Pressure Gauge
- Water Trap
Optional Equipment
- Water cooler
- Welding helmet
with special #7 shade for cutting with up to #15 shade for TIG
- Welding cart
- Consumable Kit
Recommended Metals
Virtually all metals, including aluminum, copper, stainless steel, titanium
(Exception: Power Ultra, no AC/aluminum capability)
PowerUltra 164
PowerUltra 164
PowerUltra 164
PowerUltra 164
PowerUltra 164
PowerUltra 164
PowerUltra 164
PowerUltra 164
PowerUltra 164
PowerUltra 164
PowerUltra 185
PowerUltra  205
PowerUltra 250P
PowerUltra 164 PowerUltra 185 PowerUltra 205 PowerUltra 250P
Over Current Warning Yes Yes Yes Yes
Voltage 120-240V 1PH 120-240V 1PH 120-240V 1PH 120-240V 1PH
Max Start Input Amps - - 31.3A @ 220V 45A @ 220V
Max Running Amps - - 25A @220V 37A @220V
TIG (GTAW) Rated Amps @ Duty Cycle 60%@160 A 60%@180 A 60%@200 A 250
Start Amps(Initial) None None None None
End Amps(Final) None None None None
Arc Force Control(DIG) None None None None
Up Slope Timer None None None None
Down Slope Timer None None None None
Plasma (PAC) Rated Amps @ 60% Duty Cycle 40 A 50 A 50 A 50 A
Pulse Frequency Control 0 0 0 2Position/Low/High
Pulse Time On(Width) 0 0 0 FIXED
Pulse Amp Ratio None None None FIXED
Lift Start Tig No No No No
High Frequency Start Yes Yes Yes Yes
4t/2t Remote Panel/Remote Only Panel/Remote Only Panel/Remote Only Remote/panel only
AC Frequency Control None None None None
AC Balance Control None None None None
AC Square Wave(Aluminium) No No No No
Pre-Gas Flow Timer None None None None
Post Flow Timer(seconds) 1 - 25 1 - 25 1 - 25 1-25
Stick (SMAW) Rated Amps @ Duty Cycle 160 180 200 200
Shipping Weight 55 lbs 60lbs 67 lb 67 lb
The EVERLAST PowerUltra is an ideal plasma cutter, an affordable product with a 60% duty cycle at full rated amperage and a 35% duty cycle while in stick mode. Portable and offering excellent series, this unit generate a clean and stable DC arch, handling stainless steel and other metal welding work.[read more...]
