  PowerUltra and PowerMaster series: IGBT based Inverter Tig welder/Plasma Cutter
Processes: GTAW (PowerUltra) GTAW-P (PowerMaster), SMAW, PAC
PowerUltra 164,185,205; PowerMaster 164,205,226,256
PowerMaster 164
Features & Benefits
- All-in-one portability
- Compact, yet powerful TIG welding/Plasma cutting features
- Easy to use controls with simple selector switch for process changeover
- Quick change out of torches for easy change from TIG to plasma back to TIG
- Low power consumption due to inverter design
- High duty cycle of 60% at rated amperages for TIG/Stick/Plasma
- Front air pressure gauge for easy verification of air pressure
- Over Current indicator warns when duty cycle has been exceeded
- Clean and smooth plasma cuts on virtually any metal
- Weld almost any metal (PowerUltra is DC output only, not suitable for Aluminum)
- Exceptional arc stability for TIG/Stick functions
Make an offer for PowerMaster 164
Price : $1200.99
Recommended Areas Of Use
  • For use in areas where multiple processes are required for on-the-spot repairs or fabrication in shops or home garages.
  • Typically many motorsports enthusiast like to carry these units to the track for convenient and quick high quality repairs.
  • It is also an excellent choice for the person or business with space limitations or the portable repair business as both plasma cutter and welder are contained in one unit, reducing need to carry or store two or more units.
Standard Equipment
- Torch (Water cooled torch for PowerMaster 226/256)
- Foot Pedal
- Consumable Starter Kit
- Argon Regulator
- Air Pressure Regulator
- Air Pressure Gauge
- Water Trap
Optional Equipment
- Water Cooler
- Welding Helmet with special #7 shade for cutting with up to #15 shade for TIG
- Welding Cart
- Consumable Kit
Recommended Metals
Virtually all metals, including aluminum, copper, stainless steel, titanium
(Exception: Power Ultra, no AC/aluminum capability)
PowerMaster 205 PowerMaster 226 PowerMaster 256
Voltage 220-240 V 1 ph 220-240 V 1 ph 220-240 V 1 ph
Duty Cycle @ Rated Amps 60%@200A 60%@250A 60%@250A
Start Amps(Initial) none None 0-100A
End Amps(Final) none None 0-100A
Arc Force Control(DIG) Yes Yes Yes
Up Slope Timer 0-5 S 0-10 s 0-10 s
Down Slope Timer 0-10 s 0-10 s 0-10 s
plasma cutter (pac) 50 A 60 A 60 A
Pulse Frequency Control .5-25Hz .5-25 Hz .2-500 Hz
Pulse Time On(Width) 10 10 10
Pulse Amp Ratio 5-200 A 5-250 A 5-95%
Lift Start Tig no no no
High Frequency Start Yes Yes Yes
4t/2t Remote Yes Yes Yes
AC Frequency Control 10-90% 10-90% 10-90%
AC Balance Control 20-250 Hz 20-100 Hz 20-250 Hz
AC Square Wave(Aluminium) Yes Yes Yes
Pre-Gas Flow Timer none None 0-10 s
Post Flow Timer 0-25 s 0-25 s 0-25 s
Stick(Smaw) 5-160 A 5-200 A 5-200 A
Diesel Generators | Multi-Purpose Units | Plasma Cutters | Welders | TIG Water Coolers | SAFETY Helmets Icon | Consumables | Spare Parts | Accessories | Welders Word Press | Plasma Cutter Sitemap | Welder Blog | Welding Equipment Blogspot | Welding Supply Articles | Welding Calculators | Welding Symbols | Welding Terms | Welders Schools
