Power I-Tig 200 | PowerTig 185 Micro | PowerTig 200DX | PowerTig 225 LX | PowerTig 250EX | PowerTig 315LX |
| OUTPUT POWER TYPE |
DC |
DC/AC |
DC/AC |
DC/AC |
DC/AC |
DC/AC |
| MINIMUM AMP START ON DC/AC |
5 A (UNIT IS DC ONLY) |
5 A/20 A |
5 A/20 A |
5 A/20 A |
5 A/5 A |
10/ 20 A |
| TIG(GTAW) AMPS/VOLTS @ DUTY CYCLE |
200 A, 18 V @ 35% 160 A, 16.4 V @ 60% 130 A, 15.2 V @ 100%
185 A, 17.4 V @ 35% 125 A, 15 V@ 60% 100 A, 14 V @ 100%
200 A, 18 V@ 60% 160 A, 16.4 V @ 100% -
225 A, 19 V @ 60% 175 A, 17 V @ 100% -
250 A, 20 V @ 60% 200 A, 18 V @ 100% -
315 A, 22.6 V @ 60% 250 A, 20 V @ 100% -
| TIG OPEN CIRCUIT VOLTAGE (OCV)
70 V |
70 V |
70 V |
70 V |
70 V |
70 V |
| STICK (SMAW) AMPS/VOLTS @ DUTY CYCLE |
160 A, 26.4 V @ 35% 130 A, 25.2 V @ 60% 100 A, 24 V @ 100%
NO STICK CAPABILITY
175 A, 27 V @ 35% 135 A, 25.4 V @ 60% 105 A, 24.2 V @ 100%
200 A, 28 V @ 35% 160 A, 26.4 V @ 60 % 130 A, 25.2 V @ 100%
250 A, 30 V @ 35% 200 A, 28 V @ 60% 160 A, 26.4 V
| STICK OPEN CIRCUIT VOLTAGE (OCV) |
70 V |
N/A |
70 V |
70 V |
70 V |
70 V |
| INPUT VOLTAGE/PHASE/Hz |
110-120/220-240 V 1 PH 50/60 Hz |
220-240 V 1/3 PH 50/60 Hz |
220-240 3 PH 50/60 Hz |
| INPUT AMPS MAX INRUSH (I1MAX )@ AVAILABLE VOLTAGE |
30 A @ 220 V 28.7 A @ 230 V 27.5 A @ 240 V
24.5 A @ 220 V 23.1 A @ 230 V 22.1 A @ 240 V
33.6 A @ 220 V 32.1 A @ 230 V 30.8 A @ 240 V
39 A @ 220 V 37 A @ 230 V 35 A @ 240 V
45 A/26 A @ 220 V 1/3 PH 43 A/24 A @ 230 V 1/3 PH 40 A/22 A @ 240 V 1/3 PH
32.8 A @ 220 V 31.4 A @ 230 V 30 A @ 240 V
| INPUT AMPS MAX RUNNING AMPS (I1EFF ) |
24 A @ 220 V 23 A @ 230 V 24 A @ 240 V
14.5 A @ 220 V 13.6 A @ 230 V 13 A @ 240 V
27 A @ 220 V 26 A @ 230 V 25 A @ 240 V
31 A @ 220 V 30 A @ 230 V 29 A @ 240 V
36 A/16 A @ 220 V 1/3 PH 34 A/15 A @ 230 V 1/3 PH 32 A/15 A @ 230 V 1/3 PH
25.4 A @ 220 V 24.3 A @ 230 V 23.2 A @ 240 V
| APPROX. UNIT WEIGHT (POUNDS) |
32 |
40 |
59 |
62 |
65 |
105 |
| DIMENSIONS (WxLxH) |
7.25"x16.25"x12.75" |
7.25"x19"x12.75" |
9"x21"x17" |
9"X21"x17" |
9"x21"x17" |
| FEATURES
| FOOT PEDAL |
YES/ OVERIDES PANEL AMPS WITH FULL RANGE OF AMPS AVAILABLE AT PEDAL. NO LIMIT (SUBJECT TO CHANGE. CONSULT EVERLAST.) |
YES/OVERIDES PANEL AMPS WITH FULL RANGE OF AMPS AVAILABLE AT PEDAL. NO LIMIT (SUBJECT TO CHANGE. CONSULT EVERLAST) |
YES/OVERIDES PANEL AMPS. SET/LIMIT MAX AVAILABLE AMPS ON WITH KNOB ON PEDAL. |
YES/ SET MAX AVAILABLE AMPS WITH PANEL AMP KNOB. |
YES/ OVERIDES PANEL AMPS SET/LIMIT MAX AVAILABLE AMPS WITH KNOB ON PEDAL. |
| STICK ARC FORCE CONTROL |
YES |
N/A |
NO |
NO |
YES |
YES |
| LIFT START TIG |
YES |
NO |
YES |
YES |
YES |
YES |
| HF START TIG | YES |
YES |
YES |
YES |
YES |
YES |
| SPOT TIMER | NO |
NO |
NO |
NO |
0-10 SECONDS |
NO |
| 2T/4T TORCH TRIGGER PANEL CONTROL |
YES |
2T OR PEDAL ONLY |
YES |
YES |
YES |
YES |
| START AMPS (2T/4T TRIGGER FUNCTION) |
NO, FIXED |
NO |
NO, FIXED |
NO, FIXED |
5-100 A |
NO, FIXED |
| END AMPS (2T/4T TRIGGER FUNCTION) |
NO, FIXED |
NO |
NO, FIXED |
NO, FIXED |
5-100 A |
NO, FIXED |
| UP SLOPE (2T/4T TRIGGER FUNCTION) |
0-5 SECONDS |
NO |
NO |
0-10 SECONDS |
0-10 SECONDS |
0-15 SECONDS |
| DOWN SLOPE (2T/4T TRIGGER FUNCTION) |
0-5 SECONDS |
NO |
0-5 SECONDS |
0-10 SECONDS |
0-10 SECONDS |
0-30 SECONDS |
| PRE FLOW (GAS) | 0-5 SECONDS |
AUTO .3 SECONDS |
FIXED .3 SECONDS |
0-10 SECONDS |
0-10 SECONDS |
0-10 SECONDS |
| POST FLOW(GAS) | 0-25 SECONDS |
AUTO 2-3 SECONDS |
0-25 SECONDS |
0-25 SECONDS |
0-25 SECONDS |
0-10 SECONDS |
| TIG AC FUNCTIONS
| AC FREQUENCY CONTROL |
NO AC CAPABILITY |
20-250 Hz |
20-250 Hz |
20-250 Hz |
20-250 Hz |
20- 500 Hz |
| AC BALANCE CONTROL |
NO AC CAPABILITY |
10-90% |
30-70% |
30-70% |
10-90% |
10-90% |
| TIG PULSE FUNCTIONS
| PULSE FREQUENCY RANGE | .2-250 Hz |
NO PULSE FUNCTION |
.2-25 Hz |
.2-25 Hz |
. 2-500 Hz |
.2-750 Hz |
| PULSE AMP CONTROL |
RATIO CONTROLLED: 5-95% OF WELDING AMPS -
NO PULSE FUNCTION
DIRECT AMP CONTROL
DIRECT AMP CONTROL
| PULSE TIME ON (WIDTH) | RATIO CONTROLLED: 10-90% OF PULSE CYCLE |
NO PULSE FUNCTION |
RATIO CONTROLLED 10-90% OF PULSE CYCLE |
RATIO CONTROLLED 10-90 % OF PULSE CYCLE |
| * DIRECT AMP CONTROL WORKS DIFFERENTLY WITH THE FOOT PEDAL THAN RATIO CONTROLLED UNITS. WHEN USING THE FOOT PEDAL AND PULSE TOGETHER ON DIRECT AMP CONTROL PULSE UNITS, THE PEDAL WILL ONLY CONTROL THE MAIN AMP (BASE AMPS) VALUE. THE PULSE AMPS WILL REMAIN FIXED. INCREASING PEDAL TRAVEL WILL DECREASE PULSE AMP DIFFERENTIAL.
