PowerTig 185 Micro:
Power TIG series CC IGBT inverter: 185 amp AC/DC TIG welder with adjustable AC balance and AC frequency controls.
Processes: GTAW (TIG) only.
IMPORTANT PRODUCT NOTE: Foot Pedal is optional Foot pedal controls the full range of amps only (approx 5-185A DC or 20-185A AC). The foot pedal is not controlled or limited by the panel amp adjustment. 2T Torch switch function offers panel limitation of amps. This welder is not a stick welder.
PowerTig 185 Micro
PowerTig 185 Micro
Features & Benefits
- Easy low amp 5 amp start DC, 20 amp AC.
- Compact inverter design makes it one of the lightest and smallest AC/DC IGBT based inverter welders in its class.
- Simple and easy to use controls allow any user to make high quality welds.
- Smooth stable arc in DC or AC with excellent wet in.
- Automatic pre-flow and post-flow greatly simplify setup and operation.
- Digital readout for precise control of welding amps in 2T mode.
- 2T Function with the torch switch or the optional foot pedal gives operator choices in out of position welding situations.
- DINSE 25/50 style connectors allow easy adaptation of aftermarket torches and quick setup.
No hardwired torch or work clamp improve portability and make it truly portable.
- True Square wave inverter AC output makes continuous HF unnecessary.
-Same AC frequency and AC balance control range of the PowerTig 250EX.
NOTE: For portable use: Requires a Generator designated as "Clean Power" and capable of a MINIMUM 5000 Watts of continuous output. May require higher output, for best results. Operation with generators not designated by the generator manufacturer as "clean power" may void warranty.
Make an offer for PowerTig 185 Micro
Price : $849.00
Recommended Areas Of Use
- Welding Repair
- Motorsports/Automotive
- Construction/HVAC
- Commercial/Industrial Maintenance
- Fabrication/Machine Shops
- Farm/Ranch/Agricultural
Standard Equipment
- 12ft Economy WP series 26 Air-Cooled TIG Torch
- Work Clamp
- Regulator
- Consumable Starter Pack(Tungsten not included.)
- 6 ft. input power cable (Recommended NEMA 6-50 Plug is supplied by customer).
Optional Equipment
- Foot Pedal(
- Welding Cooler
- Welding Helmet
- Consumable Kit
- Deluxe 15 or 25 ft WP series: 9,17, and 26 flex-neck torches with connectors, complete remote contactor switch for 2T operation. (Subject to availability. No substitution for standard torch. Available as an additional purchase only.)
- Dual Voltage 110V/220V (50.00) Specify at time of order.
- NEW! FINGER AMP CONTROL 17 SERIES TORCH. 15 FT. CHECK AVAILABILITY.
Recommended Metals
- Steel
- Aluminum
- Stainless Steel
- Titanium
- Copper/Nickel Alloys
- Virtually all metals.
PowerTig 185 Micro
PowerTig 185 Micro
PowerTig 185 Micro
PowerTig 185 Micro
PowerTig 185 Micro
PowerTig 185 Micro
PowerTig 185 Micro
PowerTig 185 Micro
Power I-Tig 200
PowerTig 185 Micro
PowerTig  200DX
PowerTig 225 LX
PowerTig  250EX
PowerTig 315LX
Power I-Tig 200 PowerTig 185 Micro PowerTig 200DX PowerTig 225 LX PowerTig 250EX PowerTig 315LX
OUTPUT POWER TYPE DC DC/AC DC/AC DC/AC DC/AC DC/AC
MINIMUM AMP START ON DC/AC 5 A (UNIT IS DC ONLY) 5 A/20 A 5 A/20 A 5 A/20 A 5 A/5 A 10/ 20 A
TIG(GTAW) AMPS/VOLTS @ DUTY CYCLE 200 A, 18 V @ 35%
160 A, 16.4 V @ 60%
130 A, 15.2 V @ 100%
185 A, 17.4 V @ 35%
125 A, 15 V@ 60%
100 A, 14 V @ 100%
200 A, 18 V@ 60%
160 A, 16.4 V @ 100%
225 A, 19 V @ 60%
175 A, 17 V @ 100%
250 A, 20 V @ 60%
200 A, 18 V @ 100%
315 A, 22.6 V @ 60%
250 A, 20 V @ 100%
TIG OPEN CIRCUIT VOLTAGE (OCV) 70 V 70 V 70 V 70 V 70 V 70 V
STICK (SMAW) AMPS/VOLTS @ DUTY CYCLE 160 A, 26.4 V @ 35%
130 A, 25.2 V @ 60%
100 A, 24 V @ 100%
NO STICK CAPABILITY 160 A, 26.4 V @ 35%
130 A, 25.2 V @ 60%
100 A, 24 V @ 100%
175 A, 27 V @ 35%
135 A, 25.4 V @ 60%
105 A, 24.2 V @ 100%
200 A, 28 V @ 35%
160 A, 26.4 V @ 60 %
130 A, 25.2 V @ 100%
250 A, 30 V @ 35%
200 A, 28 V @ 60%
160 A, 26.4 V
STICK OPEN CIRCUIT VOLTAGE (OCV) 70 V N/A 70 V 70 V 70 V 70 V
INPUT VOLTAGE/PHASE/Hz 110-120/220-240 V 1 PH 50/60 Hz 220-240 V 1 PH 50/60 Hz 220-240 V 1 PH 50/60 Hz 220-240 V 1 PH 50/60 Hz 220-240 V 1/3 PH 50/60 Hz 220-240 3 PH 50/60 Hz
INPUT AMPS MAX INRUSH (I1MAX )@ AVAILABLE VOLTAGE 30 A @ 220 V
28.7 A @ 230 V
27.5 A @ 240 V
24.5 A @ 220 V
23.1 A @ 230 V
22.1 A @ 240 V
33.6 A @ 220 V
32.1 A @ 230 V
30.8 A @ 240 V
39 A @ 220 V
37 A @ 230 V
35 A @ 240 V
45 A/26 A @ 220 V 1/3 PH
43 A/24 A @ 230 V 1/3 PH
40 A/22 A @ 240 V 1/3 PH
32.8 A @ 220 V
31.4 A @ 230 V
30 A @ 240 V
INPUT AMPS MAX RUNNING AMPS (I1EFF ) 24 A @ 220 V
23 A @ 230 V
24 A @ 240 V
14.5 A @ 220 V
13.6 A @ 230 V
13 A @ 240 V
27 A @ 220 V
26 A @ 230 V
25 A @ 240 V
31 A @ 220 V
30 A @ 230 V
29 A @ 240 V
36 A/16 A @ 220 V 1/3 PH
34 A/15 A @ 230 V 1/3 PH
32 A/15 A @ 230 V 1/3 PH
25.4 A @ 220 V
24.3 A @ 230 V
23.2 A @ 240 V
APPROX. UNIT WEIGHT (POUNDS) 32 40 59 62 65 105
DIMENSIONS (WxLxH) 7.25"x16.25"x12.75" 7.25"x19"x12.75" 9"x21"x17" 9"X21"x17" 9"x21"x17" -
FEATURES
FOOT PEDAL YES/ OVERIDES PANEL AMPS WITH FULL RANGE OF AMPS AVAILABLE AT PEDAL. NO LIMIT (SUBJECT TO CHANGE. CONSULT EVERLAST.) YES/OVERIDES PANEL AMPS WITH FULL RANGE OF AMPS AVAILABLE AT PEDAL. NO LIMIT (SUBJECT TO CHANGE. CONSULT EVERLAST) YES/OVERIDES PANEL AMPS. SET/LIMIT MAX AVAILABLE AMPS ON WITH KNOB ON PEDAL. YES/ SET MAX AVAILABLE AMPS WITH PANEL AMP KNOB. YES/ SET MAX AVAILABLE AMPS WITH PANEL AMP KNOB. YES/ OVERIDES PANEL AMPS SET/LIMIT MAX AVAILABLE AMPS WITH KNOB ON PEDAL.
STICK ARC FORCE CONTROL YES N/A NO NO YES YES
LIFT START TIG YES NO YES YES YES YES
HF START TIG YES YES YES YES YES YES
SPOT TIMER NO NO NO NO 0-10 SECONDS NO
2T/4T TORCH TRIGGER PANEL CONTROL YES 2T OR PEDAL ONLY YES YES YES YES
START AMPS (2T/4T TRIGGER FUNCTION) NO, FIXED NO NO, FIXED NO, FIXED 5-100 A NO, FIXED
END AMPS (2T/4T TRIGGER FUNCTION) NO, FIXED NO NO, FIXED NO, FIXED 5-100 A NO, FIXED
UP SLOPE (2T/4T TRIGGER FUNCTION) 0-5 SECONDS NO NO 0-10 SECONDS 0-10 SECONDS 0-15 SECONDS
DOWN SLOPE (2T/4T TRIGGER FUNCTION) 0-5 SECONDS NO 0-5 SECONDS 0-10 SECONDS 0-10 SECONDS 0-30 SECONDS
PRE FLOW (GAS) 0-5 SECONDS AUTO .3 SECONDS FIXED .3 SECONDS 0-10 SECONDS 0-10 SECONDS 0-10 SECONDS
POST FLOW(GAS) 0-25 SECONDS AUTO 2-3 SECONDS 0-25 SECONDS 0-25 SECONDS 0-25 SECONDS 0-10 SECONDS
TIG AC FUNCTIONS
AC FREQUENCY CONTROL NO AC CAPABILITY 20-250 Hz 20-250 Hz 20-250 Hz 20-250 Hz 20- 500 Hz
AC BALANCE CONTROL NO AC CAPABILITY 10-90% 30-70% 30-70% 10-90% 10-90%
TIG PULSE FUNCTIONS
PULSE FREQUENCY RANGE .2-250 Hz NO PULSE FUNCTION .2-25 Hz .2-25 Hz . 2-500 Hz .2-750 Hz
PULSE AMP CONTROL RATIO CONTROLLED: 5-95% OF
WELDING AMPS
NO PULSE FUNCTION DIRECT AMP CONTROL RATIO CONTROLLED: 5-95% OF
WELDING AMPS
RATIO CONTROLLED:
5-95% OF WELDING
AMPS
DIRECT AMP CONTROL
PULSE TIME ON (WIDTH) RATIO CONTROLLED: 10-90% OF PULSE CYCLE NO PULSE FUNCTION RATIO CONTROLLED 10-90% OF PULSE CYCLE RATIO CONTROLLED 10-90% OF PULSE CYCLE RATIO CONTROLLED 10-90% OF PULSE CYCLE RATIO CONTROLLED 10-90 % OF PULSE CYCLE
* DIRECT AMP CONTROL WORKS DIFFERENTLY WITH THE FOOT PEDAL THAN RATIO CONTROLLED UNITS. WHEN USING THE FOOT PEDAL AND PULSE TOGETHER ON DIRECT AMP CONTROL PULSE UNITS, THE PEDAL WILL ONLY CONTROL THE MAIN AMP (BASE AMPS) VALUE. THE PULSE AMPS WILL REMAIN FIXED. INCREASING PEDAL TRAVEL WILL DECREASE PULSE AMP DIFFERENTIAL.
The EVERLAST PowerTig 185 It has an over current warning, high frequency start, and AC square wave for aluminum welding.[read more...]
