  PowerTig Series CC Inverter: AC/DC Pulse Tig Welder
Processes: GTAW-P, SMAW
PowerTig 200 DX, 225 LX, 250 EX, 315 DX
PowerTig 200DX
Features & Benefits
- Stable, smooth arc characteristics with good puddle wet in.
- Portable and lightweight with industrial capability.
- Adjustable weld parameters for 2t/4t operation.
- Pulse function increases weld quality while reducing overall heat input.
- Easy to connect torch and accessories allow quick setup.
- Connect to clean power generator for “go anywhere” capabilities.
- Digital readout for accurate setting of amperage controls.
- Color coded controls are easy to find and understand.
- Ergonomic styled torch and accessories.
Make an offer for PowerTig 200DX
Price : $1099.99
Recommended Areas Of Use
- Welding Repair
- Motorsports/ Automotive
- Contstruction/HVAC
- Commercial maintenance
- Fabrication/machine shops
- Shipyard/pipeline industry
Standard Equipment
- Tig torch with cable
(225 LX, 250 EX, 315DX water cooled)
- Work clamp with cable
- SMAW electrode holder
- Argon regulator
- Consumable starter pack
- Foot Pedal
Optional Equipment
- Water cooler
- Welding cart
- Welding helmet
- Consumable kit
Recommended Metals
- Steel
- Aluminum (PowerTig Series only)
- Stainless Steel
- Titanium
- Copper/nickel alloys
PowerTig 200DX PowerTig 250EX PowerTig 315DX PowerTig 225 LX Power I-Tig 200
Over Current Warning YES YES YES YES YES
Voltage 220 - 240V
1 ph
220 - 240V 1-3ph 220 - 240V
3 ph ONLY
220 - 240V
1 ph
240 V 1 phase
110/240 V op-tional
Duty Cycle @ Rated Amps 35%@200 A 60%@250 A 35%@315 A 60%@225 A 60% @ 200
Start Amps(Initial) NO 0-100 A NO NO NO
End Amps(Final) NO 0-100 A NO NO NO
Arc Force Control(DIG) NO YES YES NO NO
Up Slope Timer NO 0-10 s 0-10 s 0-10 s YES
Down Slope Timer 0-5 s 0-10 s 0-10 s 0-10 s 0-5 s
Spot Timer NO 0-10 s NO NO NO
Pulse Frequency Control .5-25 Hz .5-500 Hz .5-25 Hz .5-25 Hz .5-25 Hz
Pulse Time On(Width) 10-90% 10-90% 10-90% 10-90% 10-90%
Pulse Amp Ratio 5-95% 5-95% 30-315 A 5-95% 5-200 A
Lift Start Tig YES YES NO YES NO
High Frequency Start YES YES YES YES YES
4t/2t Remote YES YES YES YES YES
AC Frequency Control 5-250 Hz 5-250 Hz 20-100 Hz 5-250 Hz NO
AC Balance Control 30-70% 10-90% 30-70% 30-70% NO
AC Square Wave(Aluminium) YES YES YES YES NO
Pre-Gas Flow Timer NO 0-10 s NO 0-10 s NO
Post Flow Timer 0-25 s 0-25 s 0-25 s 0-25 s 5/10 second selector
Stick(Smaw) 5-160 A @ 35% duty cycle 5-200 A @ 35% duty cycle 30-250 A @ 35% duty cycle 5-175 A @ 35% duty cycle 5-160 amps @ 35% duty cycle
Copyright 2004 - 2010 EverlastInc. All Rights Reserved.
Diesel Generators | Multi-Purpose Units | Plasma Cutters | Welders | TIG Water Coolers | SAFETY Helmets Icon | Consumables | Spare Parts | Accessories | Welders Word Press | Plasma Cutter Sitemap | Welder Blog | Welding Equipment Blogspot | Welding Supply Articles | Welding Calculators | Welding Symbols | Welding Terms | Welders Schools
