PowerPro 164:
All NEW! PowerPro 164 series Multi Process AC/DC IGBT Inverter: 160 A TIG/Stick welder with 40 A Plasma Cutter function
Processes: GTAW-P,SMAW, PAC
IMPORTANT PRODUCT NOTES: Foot pedal offers simple, full range control of amps, from 5-160 in TIG mode. Do not use foot pedal with Stick and Plasma cutter function. Plasma and Stick modes are DC Output only. Lines and cables on input and output sides must be changed to change between functions. Only one function can be operated at a time.
PowerPro 164
PowerPro 164
Features & Benefits
- All-in-one portability
- Compact, yet powerful TIG/Stick welding with a built in/Plasma cutting function.
- Easy to use controls with simple selector switch for process changeover
- Quick change out of torches for easy change from TIG to plasma back to TIG
- Low power consumption due to inverter design
- High duty cycle at rated amperages for TIG/Stick/Plasma
- Over Current indicator warns when duty cycle has been exceeded and interrupts welding for circuit protection
- OK to cut indicator lights up when minimum required air pressure is present
- Clean and smooth plasma cuts on virtually any metal
- Weld almost any metal
Pulse TIG mode offers great control over arc, and heat input
- Good arc stability for TIG/Stick functions with arc force control
NOTE: For use with generators, this welder requires a MINIMUM of 8,500 watts of continuous output and be designated as "clean power" by the generator manufacturer. For best results, a higher output generator may be required. Use with generators not designated by the generator manufacturer as a "clean" power source may void warranty.
Make an offer for PowerPro 164
Price : $1399.00
Recommended Areas Of Use
  • For use in areas where multiple processes are required for portable repairs.
  • Typically many motorsports enthusiast like to carry these units to the track for convenient and quick high quality repairs.
  • It is a compact option for a portable repair business not needing wanting to carry on heavy production or long term fabrication work.
Standard Equipment
- Economy Air cooled 12ft WP 26 series torch with built in remote switch for 2T/4T operation
- Foot Pedal
- Consumable Starter Kit (Tungsten not included.)
- Argon Regulator
- Air Pressure Regulator
- Air Pressure Gauge
- Water Trap (Not a dryer! Separate dryer must be supplied for customer for best results.)
Optional Equipment
- Water cooler
- Welding helmet
with special #7 shade for cutting with up to #15 shade for TIG
- Welding cart
- Consumable Kit
Deluxe, WP series, 9,17, and 26 TIG torches available in 15ft and 25ft lengths. Industry wide compatablity.
Recommended Metals
Virtually all metals, including aluminum, copper, stainless steel, titanium
PowerPro 164
PowerPro 164
PowerPro 164
PowerPro 164
PowerPro 164
PowerPro 164
PowerPro 164
PowerPro 164
PowerPro 164
PowerPro 164
PowerPro 205
PowerPro 164
PowerPro 256
PowerPro 205 PowerPro 164 PowerPro 256
Voltage 220-240 V 1 ph 220-240 V 1 ph 220-240 V 1 ph
Max Start Input Amps 33.6A @ 220V
32.1A @ 230V
30.8A @ 240V
24.8 @220V (nominal) 42 A @ 220V
40.1 A @ 230V
38.5A @ 240V
Max Running Amps 27A @ 220V
26A @230V
28A @ 240V
20 @ 220V (nominal) 35A @ 220V
34A @230V
33A @ 240V
TIG (GTAW) Rated Amps @ Duty Cycle 60%@200A 160 A @ 60% 35% @250 A
Start Amps(Initial) 0-175 A 5-160 (20-160 AC) 0-100A
End Amps(Final) 0-175 A 5-160 (20-160AC) 0-100A
Arc Force Control(DIG) Yes Yes Yes
Up Slope Timer 0-10 S 0-10 s 0-10 s
Down Slope Timer 0-25 s 0-25 s 0-10 s
Plasma (PAC) Rated Amps @ 60% Duty Cycle 50 A 40 A 60 A
Pulse Frequency Control .5-250Hz .5-250 Hz .2-500 Hz
Pulse Time On(Width) 10-90% 10-90% 10-90%
Pulse Amp Ratio 5-95% 5-95% 5-95%
Lift Start Tig No No No
High Frequency Start Yes Yes Yes
4t/2t Remote Yes Yes Yes
AC Frequency Control 10-90% 10-90% 10-90%
AC Balance Control 20-250 Hz 20-250 Hz 20-250 Hz
AC Square Wave(Aluminium) Yes Yes Yes
Pre-Gas Flow Timer 0-10s None 0-10 s
Post Flow Timer(seconds) 0-25 s 0-25 s 0-25 s
Stick (SMAW) Rated Amps @ Duty Cycle 5-160 A 5-140 A @ 35% 5-200 A
Shipping Weight 89 lb 55 lbs 105 lbs
The EVERLAST PowerPro 164 is a popular welding tool, which is similar to the PowerPro 256 and 205. The PowerPro 164 can handle to pulse TIG welds and stick welds. It can also plasma cut any metal, including stainless steel and aluminum. The product has AC/DC Pulse TIG capability, with 40 amps and severs material up to 1/2" in thickness.[read more...]
