PowerPro 226:
PowerUltra and PowerPro series: IGBT based Inverter Tig welder/Plasma Cutter
Processes: GTAW (PowerUltra) GTAW-P (PowerPro), SMAW, PAC
PowerUltra 164,185,205; PowerPro 164,205,226,256
PowerPro 226
PowerPro 226
Features & Benefits
- All-in-one portability
- Compact, yet powerful TIG welding/Plasma cutting features
- Easy to use controls with simple selector switch for process changeover
- Quick change out of torches for easy change from TIG to plasma back to TIG
- Low power consumption due to inverter design
- High duty cycle at rated amperages for TIG/Stick/Plasma
- Over Current indicator warns when duty cycle has been exceeded
- Clean and smooth plasma cuts on virtually any metal
- Weld almost any metal.
- Exceptional arc stability for TIG/Stick functions
Make an offer for PowerPro 226
Price : $1699.00
Recommended Areas Of Use
  • For use in areas where multiple processes are required for on-the-spot repairs or fabrication in shops or home garages.
  • Typically many motorsports enthusiast like to carry these units to the track for convenient and quick high quality repairs.
  • It is also an excellent choice for the person or business with space limitations or the portable repair business as both plasma cutter and welder are contained in one unit, reducing need to carry or store two or more units.
Standard Equipment
- Torch (Water cooled torch for PowerPro 226/256)
- Foot Pedal
- Consumable Starter Kit
- Argon Regulator
- Air Pressure Regulator
- Air Pressure Gauge
- Water Trap
Optional Equipment
- Water cooler
- Welding helmet
with special #7 shade for cutting with up to #15 shade for TIG
- Welding cart
- Consumable Kit
Recommended Metals
Virtually all metals, including aluminum, copper, stainless steel, titanium
(Exception: Power Ultra, no AC/aluminum capability)
PowerPro 226
PowerPro 226
PowerPro 226
PowerPro 226
PowerPro 226
PowerPro 226
PowerPro 226
PowerPro 226
PowerPro 226
PowerPro 226
PowerPro 205
PowerPro 226
PowerPro 256
PowerPro 205 PowerPro 226 PowerPro 256
Voltage 220-240 V 1 ph 220-240 V 1 ph 220-240 V 1 ph
Max Start Input Amps 33.6A @ 220V
32.1A @ 230V
30.8A @ 240V
- 42 A @ 220V
40.1 A @ 230V
38.5A @ 240V
Max Running Amps 27A @ 220V
26A @230V
28A @ 240V
- 35A @ 220V
34A @230V
33A @ 240V
TIG (GTAW) Rated Amps @ Duty Cycle 60%@200A 35% @200 A 35% @250 A
Start Amps(Initial) 0-175 A None 0-100A
End Amps(Final) 0-175 A None 0-100A
Arc Force Control(DIG) Yes Yes Yes
Up Slope Timer 0-10 S 0-10 s 0-10 s
Down Slope Timer 0-25 s 0-10 s 0-10 s
Plasma (PAC) Rated Amps @ 60% Duty Cycle 50 A 60 A 60 A
Pulse Frequency Control .5-250Hz .5-25 Hz .2-500 Hz
Pulse Time On(Width) 10-90% 10 10
Pulse Amp Ratio 5-95% 5-250 A 5-95%
Lift Start Tig No No No
High Frequency Start Yes Yes Yes
4t/2t Remote Yes Yes Yes
AC Frequency Control 10-90% 10-90% 10-90%
AC Balance Control 20-250 Hz 20-100 Hz 20-250 Hz
AC Square Wave(Aluminium) Yes Yes Yes
Pre-Gas Flow Timer 0-10s None 0-10 s
Post Flow Timer(seconds) 0-25 s 0-25 s 0-25 s
Stick (SMAW) Rated Amps @ Duty Cycle 5-160 A 5-200 A 5-200 A
Shipping Weight 89 lb 100 lbs 105 lbs
The EVERLAST PowerPro 226 is a popular welding tool, which is similar to the PowerPro 256 and 205. The PowerPro 226 can handle to pulse TIG welds and stick welds. It can also plasma cut any metal, including stainless steel and aluminum. The product has AC/DC Pulse TIG capability, with 60 amps and severs material up to 1-inch in thickness.[read more...]
