PowerPlasma 50 | PowerPlasma 60 | PowerPlasma 60C | PowerPlasma 70 | PowerPlasma 80 | PowerPlasma 100 |
| IDEAL FOR REGULARLY CUTTING A MAXIMUM OF |
1/2" (1/4" CNC CONSTANT USE) |
5/8" |
7/16" (CNC use) |
3/4" |
1" |
1" |
| MAXIMUM CUT FOR QUALITY @ 10-12 IPM (STEEL) |
3/4" |
1" |
7/8" |
1 1/8" |
1 1/4" |
1 1/2" |
| MAXIMUM SEVERANCE CUT (STEEL) |
1" |
1 1/4" (WITH OPT A 81 TORCH) |
1 1/8" |
1 3/8" (WITH OPT A 81 TORCH) |
1 1/2" (WITH OPT A81 TORCH) |
1 7/8" |
| OUTPUT AMP/VOLT RANGE |
20 A/88 V-50 A/100 V |
20 A/88 V-60 A/108 V |
20 A/88 V-60 A/104 V |
20/88V-70 A/110V |
20/88 V-80 A/112 V |
20/88 V-100 A/120 V |
| START TYPE |
CONTACT/BLOWBACK |
HIGH FREQUENCY |
HIGH VOLTAGE/LOW FREQUENCY |
HIGH FREQUENCY |
HIGH FREQUENCY |
HIGH FREQUENCY |
| PILOT ARC |
YES |
YES |
YES |
YES |
YES |
YES |
| CNC CAPABILITY |
GOOD( USER MUST SUPPLY SEPARATE CNC TORCH OR USE EXISTING HAND TORCH) |
FAIR (MUST SHIELD CABLES, UNIT SUPPLIED ONLY WITH HAND TORCH) |
EXCELLENT (CNC/TRACK TORCH SUPPLIED AS STANDARD TORCH) |
(CHECK FOR UPDATES) |
| TORCH TYPE |
S-45 |
AG60 (TRAFIMET A81 OPTIONAL/RECOMMENDED) |
P81 TRAFIMET MACHINE TORCH STANDARD |
P-80 (TRAFIMET A81 OPTIONAL/RECOMMENDED) |
TRAFIMET A101 |
| CNC PORT |
YES |
YES |
YES |
YES |
YES |
NO |
| GOUGING CAPABILITY |
LIMITED (MUST USE EXTENDED TRAFIMET TORCH CONSUMABLES AVAILABLE FROM TRAFIMET RETAIL DEALERS FOR LIMITED/LIGHT DUTY GOUGING) |
FAIR (MUST USE OPTIONAL A81 TRAFIMET TORCH AND PURCHASE GOUGING CONSUMABLES FROM TRAFIMET RETAIL DEALERS) |
NONE (AS EQUIPPED WITH STANDARD MACHINE TORCH) |
FAIR (MUST USE OPTIONAL A81 TRAFIMET TORCH WITH GOUGING CONSUMABLES AVAILABLE FROM TRAFIMET RETAIL DEALERS) |
GOOD (MUST USE TRAFIMET TORCH GOUGING CONSUMABLES AVAILABLE FROM TRAFIMET RETAIL DEALERS) |
| INPUT VOLTAGE/PHASE
220-240 V 1 PH 50/60 Hz |
220-240 V 3 PH 50/60 Hz |
220-240 V 1 PH |
220-240 V 1/3 PH |
| MAX INRUSH AMPS@RATED VOLTAGE |
220 V @ 39 A/240 V @ 37 A |
220V @ 50 A/240 V @ 46 A |
220 V @ 28.9 A/240 @ 27 A |
220 @ 60 A/ 240 V @ 55 A |
220 V @ 70 A/ 240 @ 64 A |
220 V (3) @ 45 A/240 V (3) @ 40 A |
| MAX RUNNING AMPS @ RATED VOLTAGE |
220 V @ 31 A/240 V @ 29 A |
220 V @ 40 A/240V @ 36 A |
220 V @ 23 A/240 V @ 21 A |
220 V @ 47 A/ 240 V @ 44 A |
220 V @ 55 A/240 V @ 51 A |
220 V (3) @ 35 A/240 V (3) @ 31 A |
| OPEN CIRCUIT VOLTAGE (OCV) |
200 V |
200 V |
200 V |
200 V |
200 V |
230 V |
| ADJUSTABLE POST FLOW TIMER |
YES 0-60 S/CONSTANT FLOW |
FIXED/CONSTANT FLOW |
YES 0-60S/CONSTANT FLOW |
| AMPS/VOLTS @ 60% DUTY CYCLE (10 MIN) |
50 A/100 V |
60 A/ 108 V |
60 A/104 V |
70 A/ 110 V |
80 A/ 112 V |
100 A/ 120 V |
| AMPS/VOLTS @ 100% DUTY CYCLE (10 MIN) |
40A/96 V |
46.5 A/98.6 V |
46.5 A/ 98.6 V |
55 A/ 102 V |
63 A/ 105 V |
80 A/ 112 V |
| RECOMMENDED OPERATING AIR PRESSURE |
55-65 PSI |
55-65 PSI |
55/65 PSI |
55/70 PSI |
55/70 PSI |
55/70 PSI |
| RECOMMENDED COMPRESSOR CAPACITY |
4 CFM@ 90PSI/15 GALLON |
5 CFM@ 90PSI/20 GALLON |
9 CFM@ 90PSI/ 60 GALLON |
6 CFM@ 90 PSI/ 30 GALLON |
6 CFM @ 90 PSI/ 30-60 GALLON |
8 CFM @ 90 PSI/ 60 GALLON |
| OVERCURRENT/DUTY CYCLE WARNING-INTERRUPT |
YES |
YES |
YES |
YES |
YES |
YES |
| LOW AIR PRESSURE CUT-OUT |
YES |
YES |
YES |
YES |
YES |
YES |
