Process: PAC
PowerPlasma 70
Features & Benefits
- Front air pressure adjustment makes adjusting pressure easy and painless. ( PowerPlasma only)
Make an offer for PowerPlasma 70
Price : $999.00
Recommended Areas Of Use
- Cutting in all conditions where Oxy Fuel cutting is impractical, slow,
unsafe, expensive, or otherwise restricted or undesirable.
Standard Equipment
- Torch
- Consumable starter kit
- Water trap/filter
- Air pressure gauge
Optional Equipment
- Welding helmet
- Consumable Kit
- Welding cart
Recommended Metals
PowerPlasma 50 PowerPlasma 60 PowerPlasma 60E PowerPlasma 70 PowerPlasma 80 PowerPlasma 100
Over Current Warning Yes Yes Yes Yes Yes Yes
Input Voltage 220/240 V 1ph 220/240 V 1ph 220/240 V 3ph 220/240 V 1ph 220/240 V 1ph 220/240 V 3ph
Max Start Input Amps 39A @ 220V
50A @ 220V
48A @ 230V
46A @ 240V
- - 70 A@ 220V
67A @ 230V
64A@ 240V
90A @ 220V 1phase
45A @ 220V 3 Phase
Max Running Amps 31A @ 220V
40A @ 220V
38A @ 230V
36A @ 240V
- - 55A @ 220V
53A @ 230V
51A @ 240V
60A @ 220 1 phase
35 Amp 3 phase
Pilot Arc YES YES YES YES YES YES
Input Current 39 A 50 A 27 A (3ph) 58 A 70 A 50A (3ph)
4T/2T Remote Yes Yes Yes Yes Yes Yes
OCV Voltage 200 V 200 V 200 V 200 V 200 V 200 V
Post Flow Timer 0-60 s 0-60 s 0-60 s 0-60 s 0-60 s 0-60 s
Duty Cycle @ Rated Amps 60%@ 50 A 60%@ 60 A 60%@ 60 A 60%@ 70 A 60%@ 80 A 60%@ 60 A
Maximum Severance Cut Steel(Less 20% AL/SS) 1" 1 1/8" 1 1/4" 1 3/8" 1 1/2" 1 7/8"
Recommended maximum cut @ 10-12 ipm in steel. Decrease by 25-30% for Aluminum 3/4" 7/8" 1" 1 1/8" 1 1/4" 1 5/8"
PSI/CFM Requirements 55-70 psi/ 3.5 cfm 55-70 psi/ 4.5 cfm 55-70 psi/ 4.5 cfm 50-65 psi/ 6 cfm 50-65 psi/ 7 cfm 55-70 psi/ 4.5 cfm
Shipping Weight 65 lb 65 lb - - 65 lb -
Customers, who are serious about their plasma cutters, look no further.   The PowerPlasma line offers premium cut quality and cut thickness at one of the best prices in the industry.  The 50-100 amp line of Plasma cutters offers one of the widest range of plasma cutters available, in 1 and 3 phase designs.  The proven designs are capable of being adapted to many home built and professionally manufactured CNC and track cutting systems.  Adjustable post flow increases consumable life and helps prevent torch overheating.  Each model comes ready to cut, with water trap, air connection, extra consumables and lengthy power cord.  You supply the air compressor, air line and the power plug.
If you need to cut aluminum, stainless, or steel, the pilot arc technology can help you to manage consistent cuts on the dirtiest or scrappiest piece of metal that you can find.   It also excels at cutting expanded metal quickly without the delay of having to restart the arc every time so that cutting speed is maintained without interruption.
Commercial duty cycles of 60% at maximum amperage allow you to keep cutting for extended periods of time without stopping or taking cool down breaks.  If you do over extend the duty cycle, the unit is equipped with overcurrent / overheat protection to prevent costly failures.
Take a look at the power plasma performance and design by viewing these videos here: http://www.everlastgenerators.com/video-library.php
Diesel Generators | Multi-Purpose Units | Plasma Cutters | Welders | TIG Water Coolers | SAFETY Helmets Icon | Consumables | Spare Parts | Accessories | Welders Word Press | Welders News | Sitemap | Welder Blog | Welding Equipment Blogspot | Welding Supply Articles | Welding Calculators | Welding Symbols | Welding Terms | Welding Terms Finder | Welders Schools
