Process: PAC
SuperCut 50
Features & Benefits
- High Frequency arc starting.
- Front air pressure adjustment makes adjusting pressure easy and painless. ( PowerPlasma only)
Make an offer for SuperCut 50
Price : $599.99
Recommended Areas Of Use
- Cutting in all conditions where Oxy Fuel cutting is impractical, slow,
unsafe, expensive, or otherwise restricted or undesirable.
Standard Equipment
- Torch
- Consumable starter kit
- Water trap/filter
- Air pressure gauge
Optional Equipment
- Welding helmet
- Consumable Kit
- Welding cart
Recommended Metals
SuperCut 40 SuperCut 50 SuperCut 50P
Input Voltage 110/220V 1ph 110/220V 1ph 110/220V 1ph
Max Start Input Amps - - -
Max Running Amps - - -
Pilot Arc NO NO YES
Input Current 30A 35A 35A
4T/2T Remote Yes Yes Yes
OCV Voltage 200 V 200 V 200 V
Post Flow Timer Manual/Automatic Manual/Automatic Manual/Automatic
Duty Cycle @ Rated Amps 60%@ 40 A 60%@ 50 A 60%@ 50 A
Maximum Severance Cut Steel(Less 20% AL/SS) 5/8" 3/4" 3/4"
Recommended maximum cut @ 10-12 ipm in steel. Decrease by 25-30% for Aluminum 3/8" 5/8" 5/8"
PSI/CFM Requirements 55-70 psi/ 3.5 cfm 55-70 psi/ 3.5 cfm 55-70 psi/ 3.5 cfm
Shipping Weight 28 lbs 28 lbs 28 lbs
For the homeowner, primarily concerned about the cost, we offer the SuperCut series at the best entry level price for a 40 or 50 amp plasma cutter in the industry. With our proven MOSFET based inverter design, it is lightweight and portable. The standard dual voltage capability makes it easy to run on any available current. Although cutting capacity is reduced, having multi-voltage capability can get you out of some tight spots. You will find that this cutter will handle most of the light to medium duty fabrication and repair jobs around the home and shop. If you are looking for severe duty use and performance, then you will want to consider upgrading to the PowerPlasma line.
Diesel Generators | Multi-Purpose Units | Plasma Cutters | Welders | TIG Water Coolers | SAFETY Helmets Icon | Consumables | Spare Parts | Accessories | Welders Word Press | Welders News | Plasma Cutter Sitemap | Welder Blog | Welding Equipment Blogspot | Welding Supply Articles | Welding Calculators | Welding Symbols | Welding Terms | Welding Terms Finder | Welders Schools
