PowerPlasma 100:
Process: PAC
PowerPlasma 100
PowerPlasma 100
Features & Benefits
- Front air pressure adjustment makes adjusting pressure easy and painless. ( Power Plasma only)
- Suitable for use with 20,000 W (1phase)10,000 W (3 phase) "clean power" generators.
Make an offer for PowerPlasma 100
Price : $1599.99
Recommended Areas Of Use
- Cutting in all conditions where Oxy Fuel cutting is impractical, slow, unsafe, expensive, or otherwise restricted or undesirable.
Standard Equipment
- Torch
- Consumable starter kit
- Water trap/filter
- Air pressure gauge
Optional Equipment
- Welding helmet
- Consumable Kit
- Welding cart
Recommended Metals
PowerPlasma 100
PowerPlasma 100
PowerPlasma 100
PowerPlasma 100
PowerPlasma 100
PowerPlasma 100
PowerPlasma 50
PowerPlasma 60
PowerPlasma 60C
PowerPlasma 70
PowerPlasma 80
PowerPlasma 100
PowerPlasma 50 PowerPlasma 60 PowerPlasma 60C PowerPlasma 70 PowerPlasma 80 PowerPlasma 100
IDEAL FOR REGULARLY CUTTING A MAXIMUM OF 1/2" (1/4" CNC CONSTANT USE) 5/8" 7/16" (CNC use) 3/4" 1" 1"
MAXIMUM CUT FOR QUALITY @ 10-12 IPM (STEEL) 3/4" 1" 7/8" 1 1/8" 1 1/4" 1 1/2"
MAXIMUM SEVERANCE CUT (STEEL) 1" 1 1/4" (WITH OPT A 81 TORCH) 1 1/8" 1 3/8" (WITH OPT A 81 TORCH) 1 1/2" (WITH OPT A81 TORCH) 1 7/8"
OUTPUT AMP/VOLT RANGE 20 A/88 V-50 A/100 V 20 A/88 V-60 A/108 V 20 A/88 V-60 A/104 V 20/88V-70 A/110V 20/88 V-80 A/112 V 20/88 V-100 A/120 V
START TYPE CONTACT/BLOWBACK HIGH FREQUENCY HIGH VOLTAGE/LOW FREQUENCY HIGH FREQUENCY HIGH FREQUENCY HIGH FREQUENCY
PILOT ARC YES YES YES YES YES YES
CNC CAPABILITY GOOD( USER MUST SUPPLY SEPARATE CNC TORCH OR USE EXISTING HAND TORCH) FAIR (MUST SHIELD CABLES, UNIT SUPPLIED ONLY WITH HAND TORCH) EXCELLENT (CNC/TRACK TORCH SUPPLIED AS STANDARD TORCH) FAIR (MUST SHIELD CABLES, UNIT SUPPLIED ONLY WITH HAND TORCH) FAIR (MUST SHIELD CABLES, UNIT SUPPLIED ONLY WITH HAND TORCH) (CHECK FOR UPDATES)
TORCH TYPE S-45 AG60 (TRAFIMET A81 OPTIONAL/RECOMMENDED) P81 TRAFIMET MACHINE TORCH STANDARD P-80 (TRAFIMET A81 OPTIONAL/RECOMMENDED) P-80 (TRAFIMET A81 OPTIONAL/RECOMMENDED) TRAFIMET A101
CNC PORT YES YES YES YES YES NO
GOUGING CAPABILITY LIMITED (MUST USE EXTENDED TRAFIMET TORCH CONSUMABLES AVAILABLE FROM TRAFIMET RETAIL DEALERS FOR LIMITED/LIGHT DUTY GOUGING) FAIR (MUST USE OPTIONAL A81 TRAFIMET TORCH AND PURCHASE GOUGING CONSUMABLES FROM TRAFIMET RETAIL DEALERS) NONE (AS EQUIPPED WITH STANDARD MACHINE TORCH) FAIR (MUST USE OPTIONAL A81 TRAFIMET TORCH WITH GOUGING CONSUMABLES AVAILABLE FROM TRAFIMET RETAIL DEALERS) FAIR (MUST USE OPTIONAL A81 TRAFIMET TORCH WITH GOUGING CONSUMABLES AVAILABLE FROM TRAFIMET RETAIL DEALERS) GOOD (MUST USE TRAFIMET TORCH GOUGING CONSUMABLES AVAILABLE FROM TRAFIMET RETAIL DEALERS)
INPUT VOLTAGE/PHASE 220-240 V 1 PH 50/60 Hz 220-240 V 1 PH 50/60 Hz 220-240 V 3 PH 50/60 Hz 220-240 V 1 PH 50/60 Hz 220-240 V 1 PH 220-240 V 1/3 PH
MAX INRUSH AMPS@RATED VOLTAGE 220 V @ 39 A/240 V @ 37 A 220V @ 50 A/240 V @ 46 A 220 V @ 28.9 A/240 @ 27 A 220 @ 60 A/ 240 V @ 55 A 220 V @ 70 A/ 240 @ 64 A 220 V (3) @ 45 A/240 V (3) @ 40 A
MAX RUNNING AMPS @ RATED VOLTAGE 220 V @ 31 A/240 V @ 29 A 220 V @ 40 A/240V @ 36 A 220 V @ 23 A/240 V @ 21 A 220 V @ 47 A/ 240 V @ 44 A 220 V @ 55 A/240 V @ 51 A 220 V (3) @ 35 A/240 V (3) @ 31 A
OPEN CIRCUIT VOLTAGE (OCV) 200 V 200 V 200 V 200 V 200 V 230 V
ADJUSTABLE POST FLOW TIMER YES 0-60 S/CONSTANT FLOW YES 0-60 S/CONSTANT FLOW FIXED/CONSTANT FLOW YES 0-60S/CONSTANT FLOW YES 0-60 S/CONSTANT FLOW FIXED/CONSTANT FLOW
AMPS/VOLTS @ 60% DUTY CYCLE (10 MIN) 50 A/100 V 60 A/ 108 V 60 A/104 V 70 A/ 110 V 80 A/ 112 V 100 A/ 120 V
AMPS/VOLTS @ 100% DUTY CYCLE (10 MIN) 40A/96 V 46.5 A/98.6 V 46.5 A/ 98.6 V 55 A/ 102 V 63 A/ 105 V 80 A/ 112 V
RECOMMENDED OPERATING AIR PRESSURE 55-65 PSI 55-65 PSI 55/65 PSI 55/70 PSI 55/70 PSI 55/70 PSI
RECOMMENDED COMPRESSOR CAPACITY 4 CFM@ 90PSI/15 GALLON 5 CFM@ 90PSI/20 GALLON 9 CFM@ 90PSI/ 60 GALLON 6 CFM@ 90 PSI/ 30 GALLON 6 CFM @ 90 PSI/ 30-60 GALLON 8 CFM @ 90 PSI/ 60 GALLON
OVERCURRENT/DUTY CYCLE WARNING-INTERRUPT YES YES YES YES YES YES
LOW AIR PRESSURE CUT-OUT YES YES YES YES YES YES
The EVERLAST Power Plasma 100 is a convenient and exceptionally designed product, which has a durable cycle with a rated amperage capacity of 60%.
Available in 1 and 3 phase designs, the Power Plasma is ready to cut, and has a water trap, air connection, extra consumables and lengthy power cord. You supply the air compressor, line and the power plug.[read more...]
