Process: PAC
PowerPlasma 60
Features & Benefits
- Front air pressure adjustment makes adjusting pressure easy and painless. ( PowerPlasma only)
Make an offer for PowerPlasma 60
Price : $849.99
Recommended Areas Of Use
- Cutting in all conditions where Oxy Fuel cutting is impractical, slow,
unsafe, expensive, or otherwise restricted or undesirable.
Standard Equipment
- Torch
- Consumable starter kit
- Water trap/filter
- Air pressure gauge
Optional Equipment
- Welding helmet
- Consumable Kit
- Welding cart
Recommended Metals
PowerPlasma 50 PowerPlasma 60 PowerPlasma 60E PowerPlasma 70 PowerPlasma 80 PowerPlasma 100
Over Current Warning Yes Yes Yes Yes Yes Yes
Input Voltage 220/240 V 1ph 220/240 V 1ph 220/240 V 3ph 220/240 V 1ph 220/240 V 1ph 220/240 V 3ph
Pilot Arc YES YES YES YES YES YES
Input Current 39 A 50 A 50 A 58 A 70 A 50 A
4T/2T Remote Yes Yes Yes Yes Yes Yes
OCV Voltage 200 V 200 V 200 V 200 V 200 V 200 V
Post Flow Timer 0-60 s 0-60 s 0-60 s 0-60 s 0-60 s 0-60 s
Duty Cycle @ Rated Amps 60%@ 50 A 60%@ 60 A 60%@ 60 A 60%@ 70 A 60%@ 80 A 60%@ 60 A
Maximum Severance Cut Steel(Less 20% AL/SS) 1" 1 1/8" 1 1/4" 1 3/8" 1 1/2" 1 7/8"
Recommended maximum cut @ 10-12 ipm in steel. Decrease by 25-30% for Aluminum 3/4" 7/8" 1" 1 1/8" 1 1/4" 1 5/8"
PSI/CFM Requirements 55-70 psi/ 3.5 cfm 55-70 psi/ 4.5 cfm 55-70 psi/ 4.5 cfm 50-65 psi/ 6 cfm 50-65 psi/ 7 cfm 55-70 psi/ 4.5 cfm
Diesel Generators | Multi-Purpose Units | Plasma Cutters | Welders | TIG Water Coolers | SAFETY Helmets Icon | Consumables | Spare Parts | Accessories | Welders Word Press | Plasma Cutter Sitemap | Welder Blog | Welding Equipment Blogspot | Welding Supply Articles | Welding Calculators | Welding Symbols | Welding Terms | Welders Schools
