The EVERLAST PowerCool W600 water-cooled welder is an exceptional product, which works with every EVERLAST PowerTig and PowerPro 220 unit.
The PowerCool W600 works at 160 amps and in higher TIG operations, as well as a few MIG operations.
MIG (Metal Inert Gas) uses aluminum alloy cables as a joint electrode and stuff substance. The stuff metal is added continuously; and welding is not possible if there is no filler-material available.
The Metal Inert Gas (MIG) procedure uses a straight power source, with the electrode positive (DC, EP).[read more...]
TIG welding (tungsten inert gas) is one of the best ways to weld slim pieces of stainless steel and light metals like aluminum, magnesium, and copper alloys. This welding procedure requires considerable knowledge, skill and patience.
TIG welding will be helpful for you when you desire to weld structure indoors or want to have an extremely exact weld.
Features and benefits of the PowerCool W600 include:
- * PowerCool W600 lowers the temperature of TIG torch
- * The device prevents excess humidity
- * The mechanism is compact
- * Large fans give instant relief from heat
- * The rated amperage will range somewhere around 600 + 10%
- * Stainless steel pumps
- * The machinery consists of copper construction
- * For effective operation, 220V of electric capacity is standard
- * It works with other brands of water-cooled torches.
[Collapse...]
