PowerArc 140ST:
PowerARC 140ST :
PowerARC series CC IGBT inverter: Stick/ DC Lift start TIG welder
Processes: SMAW, DC GTAW
Dual Voltage 120/240V PowerARC 140ST
PowerArc 140ST
PowerArc 140ST
Features & Benefits
-Stable, smooth DC arc
-Low Power Consumption
-Industry standard for class 35%duty cycle at rated amps.
-Portable with
-Automatic Hot Start for reduced electrode sticking
-Adaptive Arc force control
-Digital Display for easy current setting and repeatability
-DINSE 25mm style connectors for easy connection
-Lift Start DC TIG setting for steel and stainless welding
-17V series with manual gas valve built into torch handle
-140 Amp, Dual Voltage 120/240V. (85a amp max output on 120V.)
Price : $249.00
Recommended Areas Of Use
Portable Repair
Farm and Ranch
Maintenance Shops
Fabrication
Home/Hobby
HVAC
Standard Equipment
Stick Electrode Holder and Cable
17V Series Tig Torch
Minimum of 6 ft. length of Work Clamp and Cable,easily add extra lengths
High Impact Plastic Carry Case
Wire Brush
Lift Tig feature
Optional Equipment
Welding Helmet
Recommended Metals
Steel
Stainless Steel
PowerArc 140ST
PowerArc 140ST
PowerArc 140ST
PowerArc 140ST
PowerArc 140ST
PowerArc 140ST
PowerArc 140ST
PowerArc 140ST
PowerARC 160 STH
PowerARC 200
PowerARC 300
PowerArc 140ST PowerARC 160 STH PowerARC 200 PowerARC 300
Inverter Type IGBT IGBT IGBT IGBT
Max Start Input Amps 29 @ 110V, 25 @ 220V 40A @ 220V
38A @ 230V
36A @ 240V
60 A @ 240V 1 phase
47 A @ 240V 3 phase
Max Running Amps 25 @ 110V, 20 @ 220V 32A @ 220V
38A @ 230V
36A @ 240V
50 1 phase /39 3 pahse (approximate)
Process SMAW/GTAW (DC Lift Start) SMAW/ GTAW (DC w/ lift and HF start) SMAW and GTAW w/ opt. gas valve torch SMAW/GTAW (with optional gas valve torch)
Input Voltage/phase 120V/240V, 1 Phase 120V/240V 1 phase 240 V 1 phase 240 V 1 and 3 phase
Rated Output DC Amps @ 60% duty cycle 140 (240V)
85 (120V)
@ 35%
160 A (@ 35%Duty Cycle Max) 240V
95 A (35% Duty Cycle Max)
200 A 300 A
Hot Start Yes Yes Yes Yes, with adjustable surge current
Arc Force Control Yes, Auto-regulated Yes, Auto-Regulated Yes, Auto-Regulated Yes, Adjustable
Digital Amperage Display Yes Yes Yes Yes
Recommended maximum electrode size 1/8" 240V
3/32" 120V
1/8" 3/16" 1/4"
Typical Use Portable Repair, Farm, Hobby, Light fabrication Hobbyist, General Repair, Light Industrial, Fabrication, Agricultural General Repair, Fabrication, Commercial, Industrial, Factory Maintenance, Ship Yard, Pipe line, Agricultural Industrial, Pipeline, Heavy fabrication
Shipping Weight 25 lbs 35 lbs 38 lbs 50 lbs
The PowerArc 140 ST, is a lightweight inverter stick welder designed for Stick and simple DC Tig welding up to 140 amps Up against the major competition in the 140-150 inverter class, the 140 ST holds its own with excellent arc characteristics, lift arc TIG and good duty cycle performance.[read more...]
