PowerARC 300:
PowerARC series CC IGBT inverter:
Stick welder
Processes: SMAW, GTAW (with optional TIG package)
PowerARC 300
PowerARC 300
PowerARC 300
Features & Benefits
Stable, smooth DC arc
Low Power Consumption
High commercial 60% duty cycle
Portable with over the shoulder carrying strap
Hot Start with adjustable surge intensity for reduced electrode sticking
Adjustable Arc force control
Special 6010 port for better arc stability when welding with E 6010 electrodes
Suitable for Carbon arc gouging
Digital Display for precise current setting
DINSE style connectors for easy connection
Infinite amp selection.
Make an offer for PowerARC 300
Price : $589.00
Recommended Areas Of Use
Portable Welding Repair
Home garage
Maintenance shop
Factory
Fabrication
Shipyard
Pipeline
Standard Equipment
300 Amp electrode holder with cable
300 amp work clamp with cable
Recommended Metals
Steel
Stainless Steel
Aluminum (with special aluminum electrodes)
Cast Iron
PowerARC 300
PowerARC 300
PowerARC 300
PowerARC 300
PowerArc 140ST
PowerARC 160 STH
PowerARC 200
PowerARC 300
PowerArc 140ST PowerARC 160 STH PowerARC 200 PowerARC 300
Inverter Type IGBT IGBT IGBT IGBT
Max Start Input Amps 29 @ 110V, 25 @ 220V 40A @ 220V
38A @ 230V
36A @ 240V
60 A @ 240V 1 phase
47 A @ 240V 3 phase
Max Running Amps 25 @ 110V, 20 @ 220V 32A @ 220V
38A @ 230V
36A @ 240V
50 1 phase /39 3 pahse (approximate)
Process SMAW/GTAW (DC Lift Start) SMAW/ GTAW (DC w/ lift and HF start) SMAW and GTAW w/ opt. gas valve torch SMAW/GTAW (with optional gas valve torch)
Input Voltage/phase 120V/240V, 1 Phase 120V/240V 1 phase 240 V 1 phase 240 V 1 and 3 phase
Rated Output DC Amps @ 60% duty cycle 140 (240V)
85 (120V)
@ 35%
160 A (@ 35%Duty Cycle Max) 240V
95 A (35% Duty Cycle Max)
200 A 300 A
Hot Start Yes Yes Yes Yes, with adjustable surge current
Arc Force Control Yes, Auto-regulated Yes, Auto-Regulated Yes, Auto-Regulated Yes, Adjustable
Digital Amperage Display Yes Yes Yes Yes
Recommended maximum electrode size 1/8" 240V
3/32" 120V
1/8" 3/16" 1/4"
Typical Use Portable Repair, Farm, Hobby, Light fabrication Hobbyist, General Repair, Light Industrial, Fabrication, Agricultural General Repair, Fabrication, Commercial, Industrial, Factory Maintenance, Ship Yard, Pipe line, Agricultural Industrial, Pipeline, Heavy fabrication
Shipping Weight 25 lbs 35 lbs 38 lbs 50 lbs
[read more...]
