PowerARC 160 STH:
PowerARC series CC IGBT inverter: Stick welder
Processes: SMAW, GTAW
PRODUCT NOTES: This unit is equipped with a built in gas solenoid and does not require a gas valve torch. A built in switch also allows the operator to choose between High Frequency or Lift Start function with meet environmental requirements. This unit uses simple control over the amps with the optional foot pedal. This means the amp range will always be 5-160 amps (or equivalent max amps during 120 V operation). The panel amp knob does not dictate the maximum amps available at the pedal.
PowerARC 160 STH
PowerARC 160 STH
Features & Benefits
Stable, smooth DC arc
Low Power Consumption
High commercial 60% duty cycle
Portable with over the shoulder carrying strap
Easy Hot Start for reduced electrode sticking
Auto-Regulated Arc force control
Standard HF and Lift Start TIG feature
Digital Display for precise current setting
DINSE style connectors for easy connection
Impact resistant Carry case with TIG kit included as part of the standard package
Foot pedal capability offers simple control over the full amp range, from 10-160
Dual Voltage 120/240
Adjustable Post Flow control for TIG
Make an offer for PowerARC 160 STH
Price : $489.00
Recommended Areas Of Use
Portable Welding Repair
Home garage
Maintenance shop
Factory
Fabrication
Off Road
Motor Sports
Standard Equipment
300 Amp electrode holder with cable
300 amp work clamp with 10 ft cable
Built in Gas solenoid
17 series TIG torch package with built in remote trigger control
Argon Regulator
Impact resistant carry case
Recommended Metals
Steel
Stainless Steel
Aluminum (with special aluminum electrodes)
Cast Iron
NOTE: This unit is DC output only. It will not weld aluminum in TIG mode.
PowerARC 160 STH
PowerARC 160 STH
PowerARC 160 STH
PowerARC 160 STH
PowerARC 160 STH
PowerARC 160 STH
PowerARC 160 STH
PowerArc 140ST
PowerARC 160 STH
PowerARC 200
PowerARC 300
PowerArc 140ST PowerARC 160 STH PowerARC 200 PowerARC 300
Inverter Type IGBT IGBT IGBT IGBT
Max Start Input Amps 29 @ 110V, 25 @ 220V 40A @ 220V
38A @ 230V
36A @ 240V
60 A @ 240V 1 phase
47 A @ 240V 3 phase
Max Running Amps 25 @ 110V, 20 @ 220V 32A @ 220V
38A @ 230V
36A @ 240V
50 1 phase /39 3 pahse (approximate)
Process SMAW/GTAW (DC Lift Start) SMAW/ GTAW (DC w/ lift and HF start) SMAW and GTAW w/ opt. gas valve torch SMAW/GTAW (with optional gas valve torch)
Input Voltage/phase 120V/240V, 1 Phase 120V/240V 1 phase 240 V 1 phase 240 V 1 and 3 phase
Rated Output DC Amps @ 60% duty cycle 140 (240V)
85 (120V)
@ 35%
160 A (@ 35%Duty Cycle Max) 240V
95 A (35% Duty Cycle Max)
200 A 300 A
Hot Start Yes Yes Yes Yes, with adjustable surge current
Arc Force Control Yes, Auto-regulated Yes, Auto-Regulated Yes, Auto-Regulated Yes, Adjustable
Digital Amperage Display Yes Yes Yes Yes
Recommended maximum electrode size 1/8" 240V
3/32" 120V
1/8" 3/16" 1/4"
Typical Use Portable Repair, Farm, Hobby, Light fabrication Hobbyist, General Repair, Light Industrial, Fabrication, Agricultural General Repair, Fabrication, Commercial, Industrial, Factory Maintenance, Ship Yard, Pipe line, Agricultural Industrial, Pipeline, Heavy fabrication
Shipping Weight 25 lbs 35 lbs 38 lbs 50 lbs
The EVERLAST PowerARC 160 is an excellent product for both recreational and professional welders. Advanced technology ensures that these Power Arc 160 welders are reliable and effective. This product works in both DC MMA and DC TIG modes, enabling the use of standard electrodes in MMA mode with the capability to weld mild and stainless steels, alloy steels, copper, and bronze in TIG mode.
By offering 160 amps DC only at a 35 percent duty cycle, the PowerArc 160 TIG DC inverter welders have astonishing smoothness. The unit also has a fast, precise adjustment from an ultra-low 5 amps right up to an impressive 75 amps, providing great flexibility for a large number of applications.[read more...]
