Power I-Tig 200:
Product Description Summary:
Power I-Tig Series CC Inverter: 200 amp DC Pulse Tig/ 160 amp Stick Welder
Processes: GTAW-P (TIG w/Pulse), SMAW (Stick)
IMPORTANT PRODUCT NOTE: Foot Pedal is optional. Foot pedal controls the full range of amps only (approx 5-200 A). The foot pedal is not controlled or limited by the panel amp adjustment. The Torch switch with the 2T/4T function offers panel limitation of amps.
Due to our constant effort to improve and refine our product, specifications are subject to change.
Power I-Tig 200
Power I-Tig 200
Features & Benefits
- Stable, smooth arc characteristics with good puddle wet in.
- Portable and lightweight with industrial capability.
- Adjustable weld parameters for 2t/4t operation, including up and down slope adjustment.
- Fully adjustable Pulse function with up to 250Hz increases weld quality while reducing overall heat input.
- Easy to connect torch and accessories allow quick setup.
- Digital readout for accurate setting of amperage controls.
- Color coded controls are easy to locate at a glance.
- Includes an Ergonomic-styled Economy WP-26 series TIG torch (12 ft.) and accessories.
- Uses standard 35/75 series, DINSE style power connectors.
- Select for Lift Start or HF start with a flick of a switch.
- Arc force control for Stick welding increases performance.
- Recommended for E6011, E7018 and most other welding rods. Not recommended for E6010.
NOTE: For portable use: Requires a generator designated by the generator manufacturer as "clean power" and capable of a MINIMUM 6800 W of continuous output. May require higher output, for best results. Use of welder with a generator not designated by the generator manufacturer as "clean power" may void warranty.
Make an offer for Power I-Tig 200
Price : $649.99
Recommended Areas Of Use
- On-site Welding Repair
- Motorsports/ Automotive
- Contstruction/HVAC
- Commercial/Industrial Maintenance
- Fabrication/Machine Shops
- Shipyard/Pipeline
-Gun Smiths
Standard Equipment
- 12 ft Economy WP 26 series Air Cooled TIG torch (Included as part of the basic package)
- Work clamp with cable and connector
- SMAW electrode holder
- Argon regulator
- Consumable starter pack (Tungsten not included)
- 6 ft. Input power cable (Power plug not included).
Optional Equipment
- Water cooler
- Welding cart
- Welding helmet
- Consumable kit
- Foot Pedal (Foot pedal is not included as part of the I-TIG 200 basic package. Must be purchased separately)
- Deluxe, WP series compatible flex-neck TIG torch packages with DINSE connectors and remote switch: 9,17,18,20 or 26. 15 or 25 ft. lengths (Subject to availability. Offered as an additional purchase, not available for substitution.)
- NEW! FINGER AMP CONTROL 17 SERIES 15FT. TORCH. CHECK AVAILABILITY.
Recommended Metals
- Steel
- Stainless Steel
- Titanium
- Copper/nickel alloys
Unit is DC only, and will not weld aluminum or magnesium with TIG. Welds most all other metals.
Power I-Tig 200
Power I-Tig 200
Power I-Tig 200
Power I-Tig 200
Power I-Tig 200
Power I-Tig 200
Power I-Tig 200
Power I-Tig 200
Power I-Tig 200
PowerTig 185 Micro
PowerTig  200DX
PowerTig 225 LX
PowerTig  250EX
PowerTig 315LX
Power I-Tig 200 PowerTig 185 Micro PowerTig 200DX PowerTig 225 LX PowerTig 250EX PowerTig 315LX
OUTPUT POWER TYPE DC DC/AC DC/AC DC/AC DC/AC DC/AC
MINIMUM AMP START ON DC/AC 5 A (UNIT IS DC ONLY) 5 A/20 A 5 A/20 A 5 A/20 A 5 A/5 A 10/ 20 A
TIG(GTAW) AMPS/VOLTS @ DUTY CYCLE 200 A, 18 V @ 35%
160 A, 16.4 V @ 60%
130 A, 15.2 V @ 100%
185 A, 17.4 V @ 35%
125 A, 15 V@ 60%
100 A, 14 V @ 100%
200 A, 18 V@ 60%
160 A, 16.4 V @ 100%
225 A, 19 V @ 60%
175 A, 17 V @ 100%
250 A, 20 V @ 60%
200 A, 18 V @ 100%
315 A, 22.6 V @ 60%
250 A, 20 V @ 100%
TIG OPEN CIRCUIT VOLTAGE (OCV) 70 V 70 V 70 V 70 V 70 V 70 V
STICK (SMAW) AMPS/VOLTS @ DUTY CYCLE 160 A, 26.4 V @ 35%
130 A, 25.2 V @ 60%
100 A, 24 V @ 100%
NO STICK CAPABILITY 160 A, 26.4 V @ 35%
130 A, 25.2 V @ 60%
100 A, 24 V @ 100%
175 A, 27 V @ 35%
135 A, 25.4 V @ 60%
105 A, 24.2 V @ 100%
200 A, 28 V @ 35%
160 A, 26.4 V @ 60 %
130 A, 25.2 V @ 100%
250 A, 30 V @ 35%
200 A, 28 V @ 60%
160 A, 26.4 V
STICK OPEN CIRCUIT VOLTAGE (OCV) 70 V N/A 70 V 70 V 70 V 70 V
INPUT VOLTAGE/PHASE/Hz 110-120/220-240 V 1 PH 50/60 Hz 220-240 V 1 PH 50/60 Hz 220-240 V 1 PH 50/60 Hz 220-240 V 1 PH 50/60 Hz 220-240 V 1/3 PH 50/60 Hz 220-240 3 PH 50/60 Hz
INPUT AMPS MAX INRUSH (I1MAX )@ AVAILABLE VOLTAGE 30 A @ 220 V
28.7 A @ 230 V
27.5 A @ 240 V
24.5 A @ 220 V
23.1 A @ 230 V
22.1 A @ 240 V
33.6 A @ 220 V
32.1 A @ 230 V
30.8 A @ 240 V
39 A @ 220 V
37 A @ 230 V
35 A @ 240 V
45 A/26 A @ 220 V 1/3 PH
43 A/24 A @ 230 V 1/3 PH
40 A/22 A @ 240 V 1/3 PH
32.8 A @ 220 V
31.4 A @ 230 V
30 A @ 240 V
INPUT AMPS MAX RUNNING AMPS (I1EFF ) 24 A @ 220 V
23 A @ 230 V
24 A @ 240 V
14.5 A @ 220 V
13.6 A @ 230 V
13 A @ 240 V
27 A @ 220 V
26 A @ 230 V
25 A @ 240 V
31 A @ 220 V
30 A @ 230 V
29 A @ 240 V
36 A/16 A @ 220 V 1/3 PH
34 A/15 A @ 230 V 1/3 PH
32 A/15 A @ 230 V 1/3 PH
25.4 A @ 220 V
24.3 A @ 230 V
23.2 A @ 240 V
APPROX. UNIT WEIGHT (POUNDS) 32 40 59 62 65 105
DIMENSIONS (WxLxH) 7.25"x16.25"x12.75" 7.25"x19"x12.75" 9"x21"x17" 9"X21"x17" 9"x21"x17" -
FEATURES
FOOT PEDAL YES/ OVERIDES PANEL AMPS WITH FULL RANGE OF AMPS AVAILABLE AT PEDAL. NO LIMIT (SUBJECT TO CHANGE. CONSULT EVERLAST.) YES/OVERIDES PANEL AMPS WITH FULL RANGE OF AMPS AVAILABLE AT PEDAL. NO LIMIT (SUBJECT TO CHANGE. CONSULT EVERLAST) YES/OVERIDES PANEL AMPS. SET/LIMIT MAX AVAILABLE AMPS ON WITH KNOB ON PEDAL. YES/ SET MAX AVAILABLE AMPS WITH PANEL AMP KNOB. YES/ SET MAX AVAILABLE AMPS WITH PANEL AMP KNOB. YES/ OVERIDES PANEL AMPS SET/LIMIT MAX AVAILABLE AMPS WITH KNOB ON PEDAL.
STICK ARC FORCE CONTROL YES N/A NO NO YES YES
LIFT START TIG YES NO YES YES YES YES
HF START TIG YES YES YES YES YES YES
SPOT TIMER NO NO NO NO 0-10 SECONDS NO
2T/4T TORCH TRIGGER PANEL CONTROL YES 2T OR PEDAL ONLY YES YES YES YES
START AMPS (2T/4T TRIGGER FUNCTION) NO, FIXED NO NO, FIXED NO, FIXED 5-100 A NO, FIXED
END AMPS (2T/4T TRIGGER FUNCTION) NO, FIXED NO NO, FIXED NO, FIXED 5-100 A NO, FIXED
UP SLOPE (2T/4T TRIGGER FUNCTION) 0-5 SECONDS NO NO 0-10 SECONDS 0-10 SECONDS 0-15 SECONDS
DOWN SLOPE (2T/4T TRIGGER FUNCTION) 0-5 SECONDS NO 0-5 SECONDS 0-10 SECONDS 0-10 SECONDS 0-30 SECONDS
PRE FLOW (GAS) 0-5 SECONDS AUTO .3 SECONDS FIXED .3 SECONDS 0-10 SECONDS 0-10 SECONDS 0-10 SECONDS
POST FLOW(GAS) 0-25 SECONDS AUTO 2-3 SECONDS 0-25 SECONDS 0-25 SECONDS 0-25 SECONDS 0-10 SECONDS
TIG AC FUNCTIONS
AC FREQUENCY CONTROL NO AC CAPABILITY 20-250 Hz 20-250 Hz 20-250 Hz 20-250 Hz 20- 500 Hz
AC BALANCE CONTROL NO AC CAPABILITY 10-90% 30-70% 30-70% 10-90% 10-90%
TIG PULSE FUNCTIONS
PULSE FREQUENCY RANGE .2-250 Hz NO PULSE FUNCTION .2-25 Hz .2-25 Hz . 2-500 Hz .2-750 Hz
PULSE AMP CONTROL RATIO CONTROLLED: 5-95% OF
WELDING AMPS
NO PULSE FUNCTION DIRECT AMP CONTROL RATIO CONTROLLED: 5-95% OF
WELDING AMPS
RATIO CONTROLLED:
5-95% OF WELDING
AMPS
DIRECT AMP CONTROL
PULSE TIME ON (WIDTH) RATIO CONTROLLED: 10-90% OF PULSE CYCLE NO PULSE FUNCTION RATIO CONTROLLED 10-90% OF PULSE CYCLE RATIO CONTROLLED 10-90% OF PULSE CYCLE RATIO CONTROLLED 10-90% OF PULSE CYCLE RATIO CONTROLLED 10-90 % OF PULSE CYCLE
* DIRECT AMP CONTROL WORKS DIFFERENTLY WITH THE FOOT PEDAL THAN RATIO CONTROLLED UNITS. WHEN USING THE FOOT PEDAL AND PULSE TOGETHER ON DIRECT AMP CONTROL PULSE UNITS, THE PEDAL WILL ONLY CONTROL THE MAIN AMP (BASE AMPS) VALUE. THE PULSE AMPS WILL REMAIN FIXED. INCREASING PEDAL TRAVEL WILL DECREASE PULSE AMP DIFFERENTIAL.
The Everlast I-TIG 200 will weld almost any metal except aluminum.
The EVERLAST Power I-Tig 200 is a high quality, capable pulse TIG and Stick welder, which is suitable for use in nearly every setting from industrial manufacturing to beside the bench of a gun smith.[read more...]
