PowerTig 200DX:
PowerTig Series CC Inverter: AC/DC Pulse Tig Welder
Processes: GTAW-P, SMAW
PowerTig 200 DX, 225 LX, 250 EX, 315 DX
PowerTig 200DX
PowerTig  200DX
Features & Benefits
- Stable, smooth arc characteristics with good puddle wet in.
- Portable and lightweight with industrial capability.
- Adjustable weld parameters for 2t/4t operation.
- Pulse function increases weld quality while reducing overall heat input.
- Easy to connect torch and accessories allow quick setup.
- Connect to clean power generator for "go anywhere" capabilities.
- Digital readout for accurate setting of amperage controls.
- Color coded controls are easy to find and understand.
- Ergonomic styled torch and accessories.
- Suitable for use with 7500 W "clean power" generators.
Make an offer for PowerTig 200DX
Price : $1099.99
Recommended Areas Of Use
- Welding Repair
- Motorsports/ Automotive
- Contstruction/HVAC
- Commercial maintenance
- Fabrication/machine shops
- Shipyard/pipeline industry
Standard Equipment
- Tig torch with cable
(225 LX, 250 EX, 315DX water cooled)
- Work clamp with cable
- SMAW electrode holder
- Argon regulator
- Consumable starter pack
- Foot Pedal
Recommended Metals
- Steel
- Aluminum (PowerTig Series only)
- Stainless Steel
- Titanium
- Copper/nickel alloys
PowerTig  200DX
PowerTig  200DX
PowerTig  200DX
PowerTig  200DX
PowerTig  200DX
PowerTig  200DX
PowerTig  200DX
PowerTig  200DX
Power I-Tig 200
PowerTig 185 Micro
PowerTig  200DX
PowerTig 225 LX
PowerTig  250EX
PowerTig 315LX
Power I-Tig 200 PowerTig 185 Micro PowerTig 200DX PowerTig 225 LX PowerTig 250EX PowerTig 315LX
OUTPUT POWER TYPE DC DC/AC DC/AC DC/AC DC/AC DC/AC
MINIMUM AMP START ON DC/AC 5 A (DC ONLY) 5 A/20 A 5 A/20 A 5 A/20 A 5 A/5 A 10/ 20 A
TIG(GTAW) AMPS/VOLTS @ DUTY CYCLE 200 A, 18 V @ 35%
160 A, 16.4 V @ 60%
130 A, 15.2 V @ 100%
185 A, 17.4 V @ 35%
125 A, 15 V@ 60%
100 A, 14 V @ 100%
200 A, 18 V@ 60%
160 A, 16.4 V @ 100%
225 A, 19 V @ 60%
175 A, 17 V @ 100%
250 A, 20 V @ 60%
200 A, 18 V @ 100%
315 A, 22.6 V @ 60%
250 A, 20 V @ 100%
TIG OPEN CIRCUIT VOLTAGE (OCV) 70 V 70 V 70 V 70 V 70 V 70 V
STICK (SMAW) AMPS/VOLTS @ DUTY CYCLE 160 A, 26.4 V @ 35%
130 A, 25.2 V @ 60%
100 A, 24 V @ 100%
NO STICK CAPABILITY 160 A, 26.4 V @ 35%
130 A, 25.2 V @ 60%
100 A, 24 V @ 100%
175 A, 27 V @ 35%
135 A, 25.4 V @ 60%
105 A, 24.2 V @ 100%
200 A, 28 V @ 35%
160 A, 26.4 V @ 60 %
130 A, 25.2 V @ 100%
250 A, 30 V @ 35%
200 A, 28 V @ 60%
160 A, 26.4 V
STICK OPEN CIRCUIT VOLTAGE (OCV) 70 V N/A 70 V 70 V 70 V 70 V
INPUT VOLTAGE/PHASE/Hz 110-120/220-240V 1 PH 50/60 Hz 220-240 V 1 PH 50/60 Hz 220-240 V 1 PH 50/60 Hz 220-240 V 1 PH 50/60 Hz 220-240 V 1/3 PH 50/60 Hz 220-240 3 PH 50/60 Hz
INPUT AMPS MAX INRUSH (I1MAX )@ AVAILABLE VOLTAGE 30 A @ 220 V
28.7 A @ 230 V
27.5 A @ 240 V
24.5 A @ 220 V
23.1 A @ 230 V
22.1 A @ 240 V
33.6 A @ 220 V
32.1 A @ 230 V
30.8 A @ 240 V
39 A @ 220 V
37 A @ 230 V
35 A @ 240 V
45 A/26 A @ 220 V 1/3 PH
43 A/24 A @ 230 V 1/3 PH
40 A/22 A @ 240 V 1/3 PH
32.8 A @ 220 V
31.4 A @ 230 V
30 A @ 240 V
INPUT AMPS MAX RUNNING AMPS (I1EFF ) 24 A @ 220 V
23 A @ 230 V
24 A @ 240 V
14.5 A @ 220 V
13.6 A @ 230 V
13 A @ 240 V
27 A @ 220 V
26 A @ 230 V
25 A @ 240 V
31 A @ 220 V
30 A @ 230 V
29 A @ 240 V
36 A/16 A @ 220 V 1/3 PH
34 A/15 A @ 230 V 1/3 PH
32 A/15 A @ 230 V 1/3 PH
25.4 A @ 220 V
24.3 A @ 230 V
23.2 A @ 240 V
APPROX. UNIT WEIGHT (POUNDS) 32 40 59 62 65 105
DIMENSIONS (WxLxH) 7.25"x16.25"x12.75" 7.25"x19"x12.75" 9"x21"x17" 9"X21"x17" 9"x21"x17" -
FEATURES
FOOT PEDAL YES/ OVERIDES PANEL AMPS WITH FULL RANGE OF AMPS AVAILABLE AT PEDAL. NO LIMIT (SUBJECT TO CHANGE. CONSULT EVERLAST.) YES/OVERIDES PANEL AMPS WITH FULL RANGE OF AMPS AVAILABLE AT PEDAL. NO LIMIT (SUBJECT TO CHANGE. CONSULT EVERLAST) YES/OVERIDES PANEL AMPS. SET/LIMIT MAX AVAILABLE AMPS ON WITH KNOB ON PEDAL. YES/ SET MAX AVAILABLE AMPS WITH PANEL AMP KNOB. YES/ SET MAX AVAILABLE AMPS WITH PANEL AMP KNOB. YES/ OVERIDES PANEL AMPS SET/LIMIT MAX AVAILABLE AMPS WITH KNOB ON PEDAL.
STICK ARC FORCE CONTROL YES N/A NO NO YES YES
LIFT START TIG YES NO YES YES YES YES
HF START TIG YES YES YES YES YES YES
SPOT TIMER NO NO NO NO 0-10 SECONDS NO
2T/4T TORCH TRIGGER PANEL CONTROL YES 2T OR PEDAL ONLY YES YES YES YES
START AMPS (2T/4T TRIGGER FUNCTION) NO,FIXED NO NO, FIXED NO, FIXED 5-100 A NO, FIXED
END AMPS (2T/4T TRIGGER FUNCTION) NO, FIXED NO NO, FIXED NO, FIXED 5-100 A NO, FIXED
UP SLOPE (2T/4T TRIGGER FUNCTION) 0-5 SECONDS NO NO 0-10 SECONDS 0-10 SECONDS 0-15 SECONDS
DOWN SLOPE (2T/4T TRIGGER FUNCTION) 0-5 SECONDS NO 0-5 SECONDS 0-10 SECONDS 0-10 SECONDS 0-30 SECONDS
PRE FLOW (GAS) 0-5 SECONDS FIXED .3 SECONDS FIXED .3 SECONDS 0-10 SECONDS 0-10 SECONDS 0-10 SECONDS
POST FLOW(GAS) 0-25 SECONDS FIXED 2-3 SECONDS 0-25 SECONDS 0-25 SECONDS 0-25 SECONDS 0-10 SECONDS
TIG AC FUNCTIONS
AC FREQUENCY CONTROL NO AC CAPABILITY 20-250 Hz 20-250 Hz 20-250 Hz 20-250 Hz 20- 500 Hz
AC BALANCE CONTROL NO AC CAPABILITY 10-90% 30-70% 30-70% 10-90% 10-90%
TIG PULSE FUNCTIONS
PULSE FREQUENCY RANGE .2-250 Hz NO PULSE FUNCTION .2-25 Hz .2-25 Hz . 2-500 Hz .2-750 Hz
PULSE AMP CONTROL RATIO CONTROLLED: 5-95% OF
WELDING AMPS
NO PULSE FUNCTION DIRECT AMP CONTROL RATIO CONTROLLED: 5-95% OF
WELDING AMPS
RATIO CONTROLLED:
5-95% OF WELDING
AMPS
DIRECT AMP CONTROL
PULSE TIME ON (WIDTH) RATIO CONTROLLED: 10-90% OF PULSE CYCLE NO PULSE FUNCTION RATIO CONTROLLED 10-90% OF PULSE CYCLE RATIO CONTROLLED 10-90% OF PULSE CYCLE RATIO CONTROLLED 10-90% OF PULSE CYCLE RATIO CONTROLLED 10-90 % OF PULSE CYCLE
* DIRECT AMP CONTROL WORKS DIFFERENTLY WITH THE FOOT PEDAL THAN RATIO CONTROLLED UNITS. WHEN USING THE FOOT PEDAL AND PULSE TOGETHER ON DIRECT AMP CONTROL PULSE UNITS, THE PEDAL WILL ONLY CONTROL THE MAIN AMP (BASE AMPS) VALUE. THE PULSE AMPS WILL REMAIN FIXED. INCREASING PEDAL TRAVEL WILL DECREASE PULSE AMP DIFFERENTIAL.
The EVERLAST PowerTig 200 DX has both AC and DC welding capacity, along with fully modifiable AC frequency as well as balance control. There is an adjustable pulse mode for fusing hard or temperature-sensitive metals in AC and DC settings.[read more...]
