Power I-MIG 205:
Power I-MIG Series CC/CV inverter: MIG/ MAG/ Stick Welder
Processes: FCAW/ GMAW/GMAW-P
Power I-MIG 160, 200, 205, 250-P
Power I-MIG 205
Power I-MIG 205
Features & Benefits
- Smooth arc for excellent penetration with adjustable arc force control
- Capable of SMAW/Stick welding repairs for instances where MIG is not ideal
- Good duty cycle for extended welding, higher than most competitor's ratings
- High quality Binzel gun, designed with ergonomics in mind
- Eurostyle quick oupler allows easy aftermarket changeover to other style guns
- Miller style Spool Gun compatible for I-MIG 160-205 series
- Heavy duty cast aluminum wire feed assembly with positive gear driven rollers
- 4 drive roll for Power I-MIG 250P
- Flux core capable with special order drive rolls
- Over Current warning light warns when duty cycle has been exceeded
- Power I-MIG 160-200 are ideal for use in the field with a good quality portable generator
Make an offer for Power I-MIG 205
Price : $999.99
Recommended Areas Of Use
- Welding Repair
- Automotive/Muffler shops
- Motorsports
- Construction
- Fabrication
- HVAC
- Factory maintenance
Standard Equipment
- Euro style quick connector
- Binzel MIG gun and cable
- Work clamp with cable
- Spare consumable starter kit
- Argon/CO2 Regulator
Recommended Metals
- Steel
- Stainless Steel
- Chrome Moly Steel
- Aluminum: Power I-MIG 250P
- (With optional Spool gun for 160-205)
Power I-MIG 205
Power I-MIG 205
Power I-MIG 205
Power I-MIG 205
Power I-MIG 205
Power I-MIG 205
Power I-MIG 160
Power I-MIG 200
Power I-MIG 205
Power I-MIG 205 p
Power I-MIG 250 p
Power I-MIG 160 Power I-MIG 200 Power I-MIG 205 Power I-MIG 205 p Power I-MIG 250 p
OVER CURRENT WARNING YES YES YES YES YES
MAX OUTPUT CURRENT MIG (NOMINAL 240V) 160 AMPS 200 AMPS 200 AMPS 200 AMPS 250 AMPS
CURRENT, VOLTS MIG
@ RATED DUTY CYCLE
(10 MINUTE RATING @ 40° C)
135 A, 20.8 V @ 35%
100 A, 19 V @ 60%
80 A, 18 V @ 100%
160 A, 22 V@ 35%
110 A, 19.5 V @ 60%
85 A, 18.2 V @ 100%
200 A, 24 V @ 35%
155 A, 21.8 V @ 60%
120 A, 20 V @ 100%
200 A, 24 V @ 35%
155 A, 21.8 V @ 60%
120 A, 20 V @ 100%
250 A, 26.5 V @ 35%
200 A, 24 V @ 60%
160 A, 22 V @ 100%
RANGE AMPS/VOLTS, MIN/MAX MIG 30 A/15.5 V-160 /22 V 30 A/ 15.5 V-200 A/24 V 40 A/ 16 V-200 A/ 24 V 40 A/ 16 V-200 A/ 24 V 40 A/ 16 V- 250 A/ 26.5 V
MAX OUTPUT CURRENT STICK (NOMINAL 240V) 135 AMPS 160 AMPS 160 AMPS 160 AMPS 200 AMPS
CURRENT, VOLTS STICK
@ RATED DUTY CYCLE
(10 MINUTE RATING @ 40°C)
100 A, 24 V @ 35%
80 A, 23.2 V @ 60%
60 A, 22.4 @ 100%
130 A, 25.2 V @ 35%
100 A, 24 V @ 60%
77 A, 23.1 V @ 100%
RANGE AMPS/VOLTS, MIN/MAX STICK 30 A/21.2 V-135 A/24.2 V 30 A/ 21.2 V- 160 A/ 26.4 V
INPUT VOLTAGE/AMPS 110-120 V/220-240 V 110-120 V/ 220-240 V 220 V-240 V 220 V-240 V 220 V-240 V
MAX INPUT (INRUSH) AMPS @ INPUT VOLTS 18 A @ 220 V/16 A @240 V 22 A @ 220 V/20 A @ 240 V 34 A @ 220 V/32 @ 240 V 34 A @ 220 V/32 @ 240 V 40 A @ 220 V/35 @ 240 V
MAX INPUT RUNNING (EFFECTIVE) AMPS @INPUT VOLTS 9.6 A @ 220V/ 9 A @240 V 12 A @ 220 V/ 11 A @ 240 V 20 A @ 220 V/ 18.9 A @ 240 V 20 A @ 220 V/ 18.9 A @ 240 V 24 A @ 220 V/22 @ 240 V
INPUT HERTZ 50/60 Hz 50/60 Hz 50/60 Hz 50/60 Hz 50/60 Hz
OPEN CIRCUIT VOLTAGE (OCV) 60-70 60-70 70 70 70
PULSE NO NO NO YES YES
PULSE OFF SWITCH (REGULAR MIG MODE) NA NA NA NO YES
PULSE TYPE NA NA NA SINGLE SINGLE
PULSE FREQUENCY NA NA NA 20-250 Hz 20-250 Hz
PULSE WIDTH NA NA NA 10-90% 10-90%
SPOOL GUN READY YES YES YES YES YES
VARIABLE ARC FORCE CONTROL STICK (INDUCTANCE MIG) YES YES YES YES YES
WIRE ROLL SIZE (DIAMETER/ APPROX WEIGHT) 4"-8"/2-12 lb 4"-8"/2-12 lb 4"-12"/ 2-44 lb* 8"-12"/30-44 lb 8"-12"/30-44 lb
STANDARD DRIVE ROLL SIZE/ NUMBER .030-.045"/ 2 .030-.045"/ 2 .030-.045"/ 2 .030"-.045"/2 .030"-.045"/4
APPROXIMATE UNIT WEIGHT 35 lb 35 lb 45 lb 50 lb 105 lb
*special spacer must be made for use with 2 lb rolls. Consult Everlast.
Metal Inert Gas (MIG) Welding is an easy and effective welding process. The EVERLAST 160 and 200 Power I-MIG welders efficient and portable units with excellent wire roll capacity. With an 11 lb wire capacity, you won't need to be constantly changing spools while on the job. The built -in spool gun capability makes these units perfect for welding on aluminum. Exhaust and HVAC work are ideal for these products, too.
Equipped with a unique Stick weld function, the Power I MIG can also double for a scratch start TIG power supply. Easily run off a quality portable welder or generator, these machines further prove their go-anywhere character. The quality Binzel MIG welding gun the Power I-MIG series is ergonomically designed to reduce operator fatigue and improve operator comfort.[read more...]
