Plasma Cutting Torches:
40a cutting rated torch 15feet 40a cutting rated torch 15feet Code: 40ACRT15F
Price: $79.99
40a cutting rated torch 25feet 40a cutting rated torch 25feet Code: 40ACRT25F
Price: $99.99
50 amp blowback/contact start torch 15 feet. 50 amp blowback/contact start torch 15 feet. Code: 50AB/CST15F
Price: $129.99
50 amp blowback/contact start torch 25 feet. 50 amp blowback/contact start torch 25 feet. Code: 50AB/CST25F
Price: $149.99
60a cutting PILOT ARC torch rated torch 15feet 60a cutting PILOT ARC torch rated torch 15feet Code: 60ACPATRT15F
Price: $129.99
60a cutting PILOT ARC torch rated torch 25feet 60a cutting PILOT ARC torch rated torch 25feet Code: 60ACPATRT25F
Price: $149.99
60a HF rated cutting torch 15ft 60a HF rated cutting torch 15ft Code: 60AHRCT15F
Price: $129.99
60a HF rated cutting torch 25ft 60a HF rated cutting torch 25ft Code: 60AHRCT25F
Price: $149.99
70a rated PILOT ARC cutting torch 15ft 70a rated PILOT ARC cutting torch 15ft Code: 70ARPACT15F
Price: $169.99
70a rated PILOT ARC cutting torch 25ft 70a rated PILOT ARC cutting torch 25ft Code: 70ARPACT25F
Price: $189.99
80a rated HF cutting torch 15ft 80a rated HF cutting torch 15ft Code: 80ARHCT15F
Price: $159.99
80a rated HF cutting torch 25ft 80a rated HF cutting torch 25ft Code: 80ARHCT25F
Price: $179.99
80a rated PILOT ARC cutting torch 15ft 80a rated PILOT ARC cutting torch 15ft Code: 80ARPACT15F
Price: $169.99
80a rated PILOT ARC cutting torch 25ft 80a rated PILOT ARC cutting torch 25ft Code: 80ARPACT25F
Price: $189.99
80a rated PILOT ARC CNC cutting torch 25ft 80a rated PILOT ARC CNC cutting torch 25ft Code: 80ARPACCT25F
Price: $199.99
100a rated PILOT ARC cutting torch 15ft 100a rated PILOT ARC cutting torch 15ft Code: 100ARPACT15F
Price: $249.99
100a rated PILOT ARC cutting torch 25ft 100a rated PILOT ARC cutting torch 25ft Code: 100ARPACT25F
Price: $269.99
A plasma cutter is an essential welding tool for cutting metals, particularly at speeds five times faster than conventional methods. These tools work on a high voltage arc with compressed gas.
Plasma cutters simply punch through metal, courtesy of heated gas. As a result, plasma cutters can cut non-oxidizing metals such as aluminum and stainless steel, for which oxy-gas torches are ineffective.
How does plasma torch work?
* If you apply heat to gas you can create plasma. A plasma torch has an electrical arc heats the surrounding atmosphere.
* The four main components of a plasma torch are the electrical power supply, a cable to transmit the electricity, an electrode to conduct electrical heat and a nozzle to release some of the heat.
* A plasma torch must be insulated and grounded to minimize the risk of accidental shock.[read more...]
