MTS 160:
PowerMTS Series CC/CV IGBT inverter: MIG/DC TIG/Stick Welder
Processes: GMAW/ GTAW (DC)/ SMAW
MTS 160
MTS 160
Features & Benefits
-True Multi-Process design offers the perfect welder for nearly every task.
-Light- weight design makes the unit extremely portable, ideal for jobsites.
-4" or 8" Diameter wire spool capacity adds flexibility in wire type and size.
-Adjustable MIG Wave Form control manages inductance and fine tunes arc characteristics.
-Adjustable Arc Force Control allows the user to dial- in desired Stick welding performance.
- TIG Downslope allows the user to control the end of the welding cycle.
- Lift Start TIG features quick starts without problems associated with High Frequency.
- 2T/4T torch trigger/latch function offers stepped control welding with TIG and MIG.
-Automatic Pre and Post flow for TIG and MIG operation improves over all weld quality.
Make an offer for MTS 160
Price : US $999.00
  • View our PowerMTS products
  • PowerMTS specification Download
  • Know more by using PowerMTS manual
Recommended Areas Of Use
-Portable Repair On Road or Off Road
-Automotive garages/Muffler Shops
-Motor Sports Facilities
-Construction sites
-HVAC
-Factory Maintenance
-Farm
-Light Industrial Fabrication
Standard Equipment
-17 Series TIG torch features common, easy to find consumables
-Genuine Trafimet???? MIG torch with Euro style quick connect
-Stick electrode holder with cable
-Work clamp with cable
-Spare consumable starter kit
Optional Equipment
-Welding cart
-Extra Consumables
-Welding Helmet
Recommended Metals
-Steel
-Stainless Steel
MTS 160
MTS 160
MTS 160
MTS 160
MTS 160
Click Here to view more products
MTS 200
MTS 250S
MTS 200 MTS 250S
DIGITAL SYNERGIC MIG FUNCTION NO YES
MIG OUTPUT 30-200AMPS 30-250 AMPS
TIG OUTPUT 10-200 AMPS 10-250 AMPS
STICK OUTPUT 10-175 AMPS 10-200 AMPS
TIG DOWNSLOPE YES, 0-5 Seconds YES, 0-5 Seconds
MIG WAVE FORM YES YES
STICK ARC FORCE YES YES
MIG TIG PRE POST FLOW TIMER YES, 0-5 Seconds (Pre)
1-10 Seconds (Post)
1-10 Seconds (Post)
2T/4T TORCH TRIGGER STEP CONTROL YES YES
WIRE SPOOL DIAMETER 8" (12 lb max) 8" (12 lb max)
DRIVE ROLL CAPACITY .023-.045" .023-.045"
OPEN CIRCUIT VOLTAGE (STICK) 60-70 60-70
INPUT VOLTAGE 220-240 1PHASE 50/60Hz 220-240 V 1 PHASE 50/60Hz
MAX INPUT AMPS 36A 40 A
MINIMUM GENERATOR SIZE 8500 Kw 10,500 Kw
WEIGHT 45 lbs 50 lbs
size
PRODUCTS ARTICLES RESOURCES
MIG Welders for sale Plasma Cutters for sale General Tech Articles Welding Calculators
TIG Welders for sale Welding Helmets for sale Safe Welding Articles Welding Symbols
Stick Welders for sale Consumables Welding Skill Articles Welding Terms
MTS Welders for sale Tungsten Welders Topics - Join RSS - Welding Terms Finder
Spot Welders Spool Guns Welders Blog Welders Schools in USA
Submerged Arc Wire Feeders Welders News Welding Trade Shows
Multi Process Water Coolers Welding Equipment Blogspot Welders Sitemap
Diesel Generators Guns And Torches Welding Manuals Welding Videos
Welding Carts for sale Welding Accesories for sale Welder's FAQs Welder News Release
Copyright 2004 - 2012 Everlast Power Equipment Inc. All Rights Reserved.
Everlast Generators | 650-588-8082 | 329 Littlefield Ave, South San Francisco, CA 94080
While welding is a valuable skill to possess, it is important to get the right machine to do the job. If you are a professional or a hobbyist and are trying to find the machine to fit your needs, Everlast can help. We offer a full line of welders for the hobbyist and professionals, including MIG, TIG, STICK and plasma cutters. We are proud to feature IGBT components and modules from Siemens for long life service whether in the field, in the shop or in the home. Don't forget about our line of silent diesel generators and engine drive welders.
We offer convenient ordering capability without leaving your home or office.
