  PowerUltra and PowerPro series: IGBT based Inverter Tig welder/Plasma Cutter
Processes: GTAW (PowerUltra) GTAW-P (PowerPro), SMAW, PAC
PowerUltra 164,185,205; PowerPro 164,205,226,256
PowerPro 205
Features & Benefits
- All-in-one portability
- Compact, yet powerful TIG welding/Plasma cutting features
- Easy to use controls with simple selector switch for process changeover
- Quick change out of torches for easy change from TIG to plasma back to TIG
- Low power consumption due to inverter design
- High duty cycle at rated amperages for TIG/Stick/Plasma
- Over Current indicator warns when duty cycle has been exceeded
- Clean and smooth plasma cuts on virtually any metal
- Weld almost any metal
- Exceptional arc stability for TIG/Stick functions
- Suitable for use with 7500W "clean power" generators.
Make an offer for PowerPro 205
Price : $1599.00
Recommended Areas Of Use
  • For use in areas where multiple processes are required for on-the-spot repairs or fabrication in shops or home garages.
  • Typically many motorsports enthusiast like to carry these units to the track for convenient and quick high quality repairs.
  • It is also an excellent choice for the person or business with space limitations or the portable repair business as both plasma cutter and welder are contained in one unit, reducing need to carry or store two or more units.
Standard Equipment
- Torch (Water cooled torch for PowerPro 226/256)
- Foot Pedal
- Consumable Starter Kit
- Argon Regulator
- Air Pressure Regulator
- Air Pressure Gauge
- Water Trap
Optional Equipment
- Water cooler
- Welding helmet
with special #7 shade for cutting with up to #15 shade for TIG
- Welding cart
- Consumable Kit
Recommended Metals
Virtually all metals, including aluminum, copper, stainless steel, titanium
(Exception: Power Ultra, no AC/aluminum capability)
PowerPro 205 PowerPro 226 PowerPro 256
Voltage 220-240 V 1 ph 220-240 V 1 ph 220-240 V 1 ph
Max Start Input Amps 33.6A @ 220V
32.1A @ 230V
30.8A @ 240V
- 42 A @ 220V
40.1 A @ 230V
38.5A @ 240V
Max Running Amps 27A @ 220V
26A @230V
28A @ 240V
- 35A @ 220V
34A @230V
33A @ 240V
Duty Cycle @ Rated Amps 60%@200A 35% @200 A 35% @250 A
Start Amps(Initial) None None 0-100A
End Amps(Final) None None 0-100A
Arc Force Control(DIG) Yes Yes Yes
Up Slope Timer 0-5 S 0-10 s 0-10 s
Down Slope Timer 0-10 s 0-10 s 0-10 s
plasma cutter (pac) 50 A 60 A 60 A
Pulse Frequency Control .5-25Hz .5-25 Hz .2-500 Hz
Pulse Time On(Width) 10 10 10
Pulse Amp Ratio 5-200 A 5-250 A 5-95%
Lift Start Tig No No No
High Frequency Start Yes Yes Yes
4t/2t Remote Yes Yes Yes
AC Frequency Control 10-90% 10-90% 10-90%
AC Balance Control 20-250 Hz 20-100 Hz 20-250 Hz
AC Square Wave(Aluminium) Yes Yes Yes
Pre-Gas Flow Timer None None 0-10 s
Post Flow Timer 0-25 s 0-25 s 0-25 s
Stick(Smaw) 5-160 A 5-200 A 5-200 A
Shipping Weight 89 lb 100 lbs 105 lbs
The AC/DC pulse design of the PowerPro 205 offers the same quality welding capability of Everlast’s popular PowerTig series as well as offering quality cutting performance through its built in plasma cutting function. Although it’s the "entry" level unit in the PowerPro series, you do not sacrifice welding or cutting performance for the price. You have 200 amps of IGBT inverter powered welding performance and 50 amps of IGBT inverter powered cutting performance, more than enough for the typical welding job, whether it’s welding aluminum, stainless, or mild steel. A favorite choice for portable welders not wanting to buy an expensive High Frequency box to add to their welders, the PowerPro manages field tasks quite easily.
One might think that the welding and cutting features of the PowerPro 205 are compromised when compared to PowerTig and PowerPlasma series, because it is a multi process unit. No, rather, both the welding and cutting capabilities each compare favorably to the independent, separate unit. Although a dedicated unit like to PowerTig or PowerPlasma may be better suited to a production environment, the PowerPro has its own place in the industrial workplace, thanks to the convenience and portability it affords.
For the pro or hobbyist interested in aluminum welding, this unit is ideal with it’s pulse TIG design and 2t/4t panel or foot pedal control The easy starting and stable arc of the PowerPro 205 whether in DC or AC modes typically draw high praise from Everlast customers. The wide range of the AC balance control and AC frequency control allow you to customize the welding arc while welding AC. The pulse mode offers excellent heat control on thin or heat sensitive materials while welding. Complementing the versatile tig functions, the arc force control in the stick mode stabilizes the arc in out of position stick welding when a short arc length is required.
The Plasma function adds the final dimension to the PowerPro 205 with its easy to use blowback torch design with pilot arc. With 50 amps of cutting ability, quality cuts can be obtained up to ¾”. Higher severance cuts for those times when a cut through must be made are obtainable as well, although speed and quality will be lower. The built in plasma cutter handles all metal types including aluminum.
Diesel Generators | Multi-Purpose Units | Plasma Cutters | Welders | TIG Water Coolers | SAFETY Helmets Icon | Consumables | Spare Parts | Accessories | Welders Word Press | Welders News | Plasma Cutter Sitemap | Welder Blog | Welding Equipment Blogspot | Welding Supply Articles | Welding Calculators | Welding Symbols | Welding Terms | Welding Terms Finder | Welders Schools
