EV-MIG250D:
EV-MIG250D
EV-MIG250D
Features & Benefits
Make an offer for EV-MIG250D
Price : $1199.99
EV-MIG250D
EV-MIG250D
EV-MIG250D
EV-MIG250D
EV-MIG250D
EV-MIG250D
EV-MIG250D
EV-MIG250D
EV-MIG250D
EV-MIG250D
Power I-MIG 160
Power I-MIG 200
Power I-MIG 205
Power I-MIG 205 p
Power I-MIG 250 p
Power I-MIG 160 Power I-MIG 200 Power I-MIG 205 Power I-MIG 205 p Power I-MIG 250 p
OVER CURRENT WARNING YES YES YES YES YES
MAX OUTPUT CURRENT MIG (NOMINAL 240V) 160 AMPS 200 AMPS 200 AMPS 200 AMPS 250 AMPS
CURRENT, VOLTS MIG
@ RATED DUTY CYCLE
(10 MINUTE RATING @ 40° C)
135 A, 20.8 V @ 35%
100 A, 19 V @ 60%
80 A, 18 V @ 100%
160 A, 22 V@ 35%
110 A, 19.5 V @ 60%
85 A, 18.2 V @ 100%
200 A, 24 V @ 35%
155 A, 21.8 V @ 60%
120 A, 20 V @ 100%
200 A, 24 V @ 35%
155 A, 21.8 V @ 60%
120 A, 20 V @ 100%
250 A, 26.5 V @ 35%
200 A, 24 V @ 60%
160 A, 22 V @ 100%
RANGE AMPS/VOLTS, MIN/MAX MIG 30 A/15.5 V-160 /22 V 30 A/ 15.5 V-200 A/24 V 40 A/ 16 V-200 A/ 24 V 40 A/ 16 V-200 A/ 24 V 40 A/ 16 V- 250 A/ 26.5 V
MAX OUTPUT CURRENT STICK (NOMINAL 240V) 135 AMPS 160 AMPS 160 AMPS 160 AMPS 200 AMPS
CURRENT, VOLTS STICK
@ RATED DUTY CYCLE
(10 MINUTE RATING @ 40°C)
100 A, 24 V @ 35%
80 A, 23.2 V @ 60%
60 A, 22.4 @ 100%
130 A, 25.2 V @ 35%
100 A, 24 V @ 60%
77 A, 23.1 V @ 100%
RANGE AMPS/VOLTS, MIN/MAX STICK 30 A/21.2 V-135 A/24.2 V 30 A/ 21.2 V- 160 A/ 26.4 V
INPUT VOLTAGE/AMPS 110-120 V/220-240 V 110-120 V/ 220-240 V 220 V-240 V 220 V-240 V 220 V-240 V
MAX INPUT (INRUSH) AMPS @ INPUT VOLTS 18 A @ 220 V/16 A @240 V 22 A @ 220 V/20 A @ 240 V 34 A @ 220 V/32 @ 240 V 34 A @ 220 V/32 @ 240 V 40 A @ 220 V/35 @ 240 V
MAX INPUT RUNNING (EFFECTIVE) AMPS @INPUT VOLTS 9.6 A @ 220V/ 9 A @240 V 12 A @ 220 V/ 11 A @ 240 V 20 A @ 220 V/ 18.9 A @ 240 V 20 A @ 220 V/ 18.9 A @ 240 V 24 A @ 220 V/22 @ 240 V
INPUT HERTZ 50/60 Hz 50/60 Hz 50/60 Hz 50/60 Hz 50/60 Hz
OPEN CIRCUIT VOLTAGE (OCV) 60-70 60-70 70 70 70
PULSE NO NO NO YES YES
PULSE OFF SWITCH (REGULAR MIG MODE) NA NA NA NO YES
PULSE TYPE NA NA NA SINGLE SINGLE
PULSE FREQUENCY NA NA NA 20-250 Hz 20-250 Hz
PULSE WIDTH NA NA NA 10-90% 10-90%
SPOOL GUN READY YES YES YES YES YES
VARIABLE ARC FORCE CONTROL STICK (INDUCTANCE MIG) YES YES YES YES YES
WIRE ROLL SIZE (DIAMETER/ APPROX WEIGHT) 4"-8"/2-12 lb 4"-8"/2-12 lb 4"-12"/ 2-44 lb* 8"-12"/30-44 lb 8"-12"/30-44 lb
STANDARD DRIVE ROLL SIZE/ NUMBER .030-.045"/ 2 .030-.045"/ 2 .030-.045"/ 2 .030"-.045"/2 .030"-.045"/4
APPROXIMATE UNIT WEIGHT 35 lb 35 lb 45 lb 50 lb 105 lb
*special spacer must be made for use with 2 lb rolls. Consult Everlast.
